Date/Time: Fri, 07 Feb 2025 21:21:46 +0000
Disable past order fills feature
View Count: 522
[2020-06-16 21:38:13]
User104854 - Posts: 457
I have version 2120 and have a question on the following which is from the 'What Is New' section:
'Support for replaying past simulated trade fills. When replaying a chart, when in chart trade mode and there were past order fills which have not been cleared, as the time is encountered in the chart where the order fill occurs, then it will display on the chart if the chart is set to display order fills.'
Can this feature be disabled, or can the user decide if he or she wants it active or not? I automate a lot and it's not uncommon for me to replay a trade multiple times until I'm satisfied with the execution. Please advise.
Thank you.
[2020-06-17 00:02:16]
No it cannot be disabled. When you are running a replay and you do not want to see any past order fills, switch to a different simulated Trade Account on the Trade Window.
