Date/Time: Sat, 20 Jun 2026 22:50:33 +0000
Trade DOM header coloring
View Count: 749
[2020-06-16 20:29:48]
joshtrader - Posts: 563
I like the new Trade DOM header. As the picture shows, I have used reverse coloring and the DChg is red/green. Is it possible to also color the PQ (position quantity) the same way (green for long, red for short)? Also, if it would be possible to specify the background color and text color for any of these fields, it would be cool -- is that possible? (to color it differently per DOM, for example)
Date Time Of Last Edit: 2020-06-16 20:31:24
imagepq.PNG / V - Attached On 2020-06-16 20:29:30 UTC - Size: 12.57 KB - 322 views
[2020-06-17 10:56:42]
We will have to look at more customized coloring later on.
