Date/Time: Fri, 07 Feb 2025 23:30:05 +0000
Open New Account and Setup
View Count: 577
[2020-06-16 16:29:09] |
anilchou - Posts: 6 |
I am using the free trial that is about to expire. I am still not much familiar with Sierra Chart and data services needed for TPO and Volume Profile and am hoping to talk to someone who can guide me which Account, Services and Data feeds are needed to run tpo/volume profile for equity indices (ES, YM, NQ) as well as currencies? I would also like to know the pricing and discounts, if any available. currently I am using Tradestation and Thinkorswim. |
[2020-06-17 02:24:29] |
One question we have is do you require real-time data for those futures markets? That is the first question we need answered. If so, this complicates data access. Refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-17 02:24:51
[2020-06-17 19:29:41] |
Yes, I am looking for real time data for TPO profiles for ES-mini, Thanks
[2020-06-17 19:49:44] |
Ok we recommend using the Denali Exchange Data Feed for the real-time data for ES: Denali Exchange Data Feed For a supported trading account we recommend this solution if you do not have one: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
