Date/Time: Fri, 07 Feb 2025 22:54:01 +0000
Datafeed with two programs parallel
View Count: 674
[2020-06-16 16:27:22] |
Rustam - Posts: 19 |
Hi. I use two programs for tardening, Sierra Chart and Atas. I do the volume analysis at Atas and I trade with sierra chart. Now there is the problem that it is no longer possible to run two programs at the same time without being classified as professional. An acquaintance wrote to me that it is possible with 2 accounts from a broker and a special package from sierra chart and that the package cannot simply be booked on the homepage. I would be very grateful for help. I am currently using rithmic and AMP as a broker |
[2020-06-17 02:31:32] |
The solution to this is to use the Denali Exchange Data Feed for market data: Denali Exchange Data Feed You can access the data is little as $23 a month. That is very economical. And since you have an account with AMP you will then be entitled to the nonprofessional exchange fees assuming you are a nonprofessional. To authorize the data though requires that you do have a TT account set up with AMP. So you will want to use this service: Sierra Chart / Trading Technologies Futures Order Routing Service You can still use Rithmic separately with the other program. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-17 02:32:04
[2020-06-18 15:11:19] |
So as an example: I open a sub-account at AMP with the denali feed and then use Sierra Chart and with the rithmic account Atas. With Sierra Chart with the Denali feed do I then set that I enter into a trade, a position with Denali and a position with rithmic at the same time? Have I understood that correctly ? Or should the Denali Feed only deliver the market data? |
[2020-06-19 05:13:44] |
With Sierra Chart with the Denali feed do I then set that I enter into a trade, a position with Denali and a position with rithmic at the same time? Yes if this is what you want to do. You would be using the Sierra Chart Order Routing Service in this case:Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
