Date/Time: Fri, 07 Feb 2025 21:27:36 +0000
Dati forex non aggiornati
View Count: 532
[2020-06-16 16:03:43] |
GIOVANNI ZANANTONI - Posts: 2 |
Buongiorno da qualche oraa ho i dati del cambio eur/usd totalmente differenti da quelli reali come mai? grazie
[2020-06-16 16:10:49] |
ticinotrader - Posts: 401 |
Same happens here and with other users in my group. The EURUSD pair's data does not update in realtime. I'm using SC v2120 and SC datafeed. Can you please advise? |
[2020-06-17 02:40:51] |
We get this data from FXCM and they had a problem today (2020-06-16). We recommend that you set up an LMAX demo account. Follow the instructions here: LMAX Trading Service And then you can set up a separate installation of Sierra Chart to use with LMAX: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-17 02:41:05
