Date/Time: Fri, 07 Feb 2025 23:25:05 +0000
Feature request: Flash the chart tab that's alerting
View Count: 774
[2020-06-16 14:00:31]
Matt NL - Posts: 91
I have a lot of open charts, timeframes etc. Like 25.
When I hear an audio alert I have to check the alerts log, fine the chart number, then go through the window menu and painfully find the chart number (because the number isn't first in the list).
I would be great if you could make the chart tab flash which is triggering the alert.
Matt
[2020-06-16 15:59:20]
phaedonk - Posts: 352
I second this request.
Bear in mind, you can double click the alert line and the window will be selected.
[2020-06-18 15:03:16]
You can already select the alert line in the Window >>Alert Manager >> Log and go to the chart. Refer to:
Alerts Manager: Alert Manager Controls
[2020-06-19 08:56:35]
Matt NL - Posts: 91
Thanks to both of you. I didn't know that. That really helps!
