Date/Time: Tue, 06 Oct 2026 01:57:07 +0000
2nd instance
View Count: 989
[2020-06-16 13:23:14]
Robert Wojczak - Posts: 178
I understand that I can run 2 instances of SC simotenously. I know I will have to subscribe to another CME feed. But will I need to subscribe to another Denali feed
[2020-06-16 20:36:39]
If the instances of Sierra Chart are on the same computer, then you do not need to pay for any additional data connections.
If the instances are on different computers, then you would need to pay for an additional exchange fee as part of your Denali Exchange Data Feed.
It is just the exchange fee that is doubled. And you are only able to use the same CME Exchange. If this is your setup and you want to activate the additional CME Exchange, then let us know. We can help with that.
[2020-06-16 22:32:38]
So I would pay for 1 Denali exchange fee and 2 CME fee's and be able to have it working simultaneously on my laptop and desk top?
[2020-06-17 02:59:32]
Yes that is correct.
[2020-06-17 08:16:41]
Thank you very much. I more question if i activate another CME now. I know it runs to the end of the month. Is it Pro rated?
[2020-06-17 11:44:27]
No absolutely not, the exchange does not do that.
[2020-06-17 12:19:07]
Ok If I want to activate the 2nd cme how do i do that? also starting july 1 i would like to change my current exchange to the full cme package. Not the individual exchanges. How do I do that with out getting charged? Cancel the existing on the last day of the month. Thank you
[2020-06-17 19:52:45]
Sierra Chart - Max - Posts: 5972
You can activate the 2nd system for CME here:
To change Exchange options, you would first need to deactivate the exchanges that you do not want to renew.
You will have the option to activate the new exchange option now and get charged for the current month, or wait until the start of the next month to activate it.
Sierra Chart Support
