Date/Time: Fri, 07 Feb 2025 21:17:55 +0000
Web platform?
View Count: 542
[2020-06-16 12:16:49] |
User541156 - Posts: 67 |
There use to be rumours (and if I remember correctly even a forum post) that basic web platform which will let you handle orders from web phone. Is that still coming? Is there any way, if I go with Sierra Chart and its order routing to see and manage my orders through a weblink or phone? |
[2020-06-16 20:22:56] |
This is available now when using the Sierra Chart Order Routing service. Refer to the information here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#WebBasedTradingPanel Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
