Date/Time: Mon, 25 Nov 2024 07:56:32 +0000
IB Mapping Eur and GBP for SC Real Time
View Count: 1079
[2014-01-26 23:28:19]
User94740 - Posts: 333
Hi SC, I believe there is a huge error for the mapping of EUR and GBP. GBP shows the same price data as EUR.
http://www.sierrachart.com/image.php?l=1390778854643.png
http://www.sierrachart.com/image.php?l=1390778869287.png
[2014-01-26 23:50:20]
We have checked the mapping settings for these particular Interactive Brokers symbols and they are correct.
We recommend updating the symbol settings as explained here:
http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings
Make sure you reconnect to the data feed after updating the symbol settings.
After that go to the chart and select Edit >>Delete All Data and Download.
Date Time Of Last Edit: 2014-01-27 00:24:15
[2014-01-27 00:38:37]
I had done this and before I started using SC Real Time it was working correctly. I have uploaded the log.
[2014-01-27 00:46:15]
Perform a Full Reset of the Symbol Settings then:
The mapping is definitely correct but maybe the symbol settings are not correct on your side for some unknown reason.
Here is a chart we just opened for the British pound futures using Interactive Brokers and the Sierra Chart data feed:
http://www.sierrachart.com/image.php?l=1390783387919.png
Date Time Of Last Edit: 2014-01-27 00:47:05
