Date/Time: Fri, 07 Feb 2025 21:34:24 +0000
London Relay
View Count: 546
[2020-06-15 22:02:14] |
Ben A - Posts: 123 |
Hi, I have noticed that there is a London relay for Denali Data-I am located in London and use Denali + IB. Does it make sense for me to use the London relay and is that possible to set up? Kind Regards, Ben |
[2020-06-17 03:45:29] |
No you cannot currently use that relay server when using Interactive Brokers. Unless you have connectivity problems it is not going to really help.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-17 03:45:43
