Date/Time: Fri, 07 Feb 2025 20:54:23 +0000
Painting Moving Averages above Histogram on True Strength Indicator
View Count: 574
[2020-06-15 21:48:09] |
meandthetrio - Posts: 3 |
As the title states, I would simply like to have my moving averages display on top of my histogram bars because they get covered up depending on histogram bar thickness. Would I just need to create a custom study using Sierra's TSI code as a template?
[2020-06-15 23:00:57] |
Ackin - Posts: 1865 |
Did you try to use TSI with moving average based on TSI? Based On (MA study settings) Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study |
[2020-06-15 23:18:02] |
I am actually trying to get the TSI and Signal line on top of the histograms for the indicator but that is a good idea. I guess I could just set the MAs to zero and hide the original lines. Thank you
[2020-06-17 11:11:58] |
Refer to: Chart Studies: Study Display Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
