Date/Time: Fri, 07 Feb 2025 21:21:59 +0000
Reorder detached windows not working
View Count: 624
[2020-06-15 18:05:46]
greg9 - Posts: 9
SierraChart
I tried to reorder detached windows using this method: Detaching and Attaching Chart Windows: Internal Ordering of Detached Charts
I've saved SC, closed, reopened but its not opening in this order. Its ignoring the order in the setting and defaulting to the order in which I first opened them. Any trick to this that I'm missing?
[2020-06-15 19:44:47]
This does not make sense to us. If you change the order of the charts, in the Window >> Windows and Chartbooks list, and save the Chartbook, that will be the order they will be in. There really is no other possibility.
Date Time Of Last Edit: 2020-06-15 19:45:24
[2020-06-15 20:36:02]
greg9 - Posts: 9
I know, it should work but I'm not seeing it work. I've tried closing and reopening, ordering differently. Still the same. See below link
I have them ordered from daily on the left down to 1 min, 30 sec on the right. As you can see in the screenshot they aren't ordering that way.
https://drive.google.com/file/d/1tULEAmSSFkvHHDoCROk_uGxyTcYzFRcf/view?usp=sharing
[2020-06-17 11:18:54]
We do not see how we can help with this. How they are ordered on the taskbar is not within our control.
