Date/Time: Fri, 07 Feb 2025 19:53:41 +0000
EUREX data feed
View Count: 1204
[2020-06-15 16:48:40] |
Https://tradingbalance.co.uk - Posts: 44 |
Hi, I ve been having issues with my EUREX data feed and number bar display. The values are sometimes corrupted with large bid/ offer trades that do not exist. I have tried to delete the data, reinstall sierra, and whilst data looks fine for a few ticks eventually a large traded order will be displayed that makes the calculated number bars look very wrong. I had a similar issue with S&Pmini data but the restart seems to have fixed this for now. There are no similar issues/fixes on the forum so I thought I would ask. Is this an issue with the new EUREX feed that I now purchase through you directly? many thanks https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=40212 |
[2020-06-15 17:04:16] |
We responded to you here already about this: EUREX data issues, missing bid ask executed trades and large spurious trades. You are not currently subscribed to this data feed. Is this an issue with the new EUREX feed that I now purchase through you directly?
And also you need to use the Denali Exchange Data Feed for reliable CME group data instead of Interactive Brokers data: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-15 17:04:40
