Date/Time: Sat, 08 Feb 2025 00:13:09 +0000
Chart trading order lines no longer showing ticks
View Count: 972
[2020-06-15 15:10:37] |
jakesans - Posts: 50 |
Hi SC, Downloaded latest version 2118. My order lines for chart trading switched to showing points instead of ticks. I made no changes on my side. Please fix. Thanks, Jake |
[2020-06-16 03:15:45] |
We corrected a problem related to that profit/loss display. You can change the Profit/Loss Format with this setting: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-16 03:17:43
[2020-06-17 16:05:31] |
What about the open order lines and child order lines? I used to see ticks, now I see points. The solution provided above doesn't seem to have any effect on them. Please advise. Thanks, Jake |
[2020-06-17 20:16:00] |
Are you wanting to see Ticks when you modify the order lines?
[2020-06-18 22:07:23] |
Yes exactly. I used to see ticks when moving order lines until the last update I referenced above, now I see points which I don't want.
[2020-06-22 20:05:51] |
Okay, we will solve this. But it will always be according to this Profit/Loss setting: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-22 23:44:00] |
Thanks so much! Yes, understood. I use "ticks w/o quantity" P/L setting so that solution should be satisfactory.
