Date/Time: Fri, 25 Sep 2026 06:00:30 +0000
Hello, please advise, I can't connect to the data. Thanks for the answer.
View Count: 860
[2020-06-15 14:05:15]
User446762 - Posts: 2
Reading Internal Order ID file. | 2020-06-15 15:43:54.848
Reading Trade Orders file. | 2020-06-15 15:43:55.006
Reading Trade Positions file. | 2020-06-15 15:43:55.007
Reading Account Balance file. | 2020-06-15 15:43:55.009
UDPListener (1492). Port 22903 | Listening on UDP port 22903. | 2020-06-15 15:43:55.034
Software version: 2118 32-bit | 2020-06-15 15:43:55.036
Primary Thread ID: 14156 | 2020-06-15 15:43:55.037
Enabled for: Advanced Features 2. | 2020-06-15 15:43:55.037
Enabled for: Sierra Chart Historical Data Service. | 2020-06-15 15:43:55.037
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-06-15 15:43:55.037
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-06-15 15:43:55.037
Current selected Data/Trading service: Rithmic Trading | 2020-06-15 15:43:55.037
Custom symbol settings values: disabled | 2020-06-15 15:43:55.037
Chart Update Interval: 900 | 2020-06-15 15:43:55.037
Intraday Data Storage Time Unit: 0 | 2020-06-15 15:43:55.037
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2020-06-15 15:43:55.037
2020-06-15 15:43:55 Local computer time | 2020-06-15 15:43:55.037
2020-06-15 13:43:55 Local computer time in UTC | 2020-06-15 15:43:55.037
2020-06-15 15:43:55 Local computer time in SC Time Zone | 2020-06-15 15:43:55.037
2020-06-15 13:43:54 Server time in UTC | 2020-06-15 15:43:55.037
Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-06-15 15:43:55.037
Program path: C:\SierraChart\ | 2020-06-15 15:43:55.037
Data Files path: C:\SierraChart\Data\ | 2020-06-15 15:43:55.037
OS Version Number: 10.0 | 2020-06-15 15:43:55.037
Locale Setting: C | 2020-06-15 15:43:55.037
Allowed protected custom studies: | 2020-06-15 15:43:55.037
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 1. | 2020-06-15 15:43:55.037
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-06-15 15:43:55.131
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-06-15 15:43:55.149
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-06-15 15:43:55.149
Received 5 login tokens. | 2020-06-15 15:43:55.178
Symbol settings MD5 received. Request ID: 1. | 2020-06-15 15:43:55.381
Symbol settings are up-to-date for rithmic.trading. | 2020-06-15 15:43:55.381
Rithmic Trading | Port for executable: 55868 | 2020-06-15 15:44:00.175
Listening socket (1528). Port 55868 | Closed. | 2020-06-15 15:44:00.175
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:44:00.176
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55868. Current folder: C:\SierraChart\Rim | 2020-06-15 15:44:00.216
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:44:02.203
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55868 | 2020-06-15 15:44:02.203
DTC Client socket (1) | Creating socket. | 2020-06-15 15:44:02.203
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:44:02.203
DTC Client socket (1) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:44:04.208 *
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:44:04.208
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:44:04.208
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:04.208
DTC Client socket (1) | Closed. | 2020-06-15 15:44:04.209
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:44:04.219
Rithmic Trading | Disconnected. | 2020-06-15 15:44:04.219
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:04.219
Rithmic Trading | Port for executable: 55870 | 2020-06-15 15:44:06.233
Listening socket (1556). Port 55870 | Closed. | 2020-06-15 15:44:06.233
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:44:06.234
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55870. Current folder: C:\SierraChart\Rim | 2020-06-15 15:44:06.274
Rithmic Trading | Bridge process is running. | 2020-06-15 15:44:08.271
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55870 | 2020-06-15 15:44:08.271
DTC Client socket (1) | Creating socket. | 2020-06-15 15:44:08.271
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:44:08.271
Rithmic Trading | Connected to server. | 2020-06-15 15:44:08.272
Rithmic Trading | Starting socket receive thread. | 2020-06-15 15:44:08.272
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-15 15:44:08.274
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-15 15:44:08.274
Rithmic Trading | Sending logon request message. | 2020-06-15 15:44:08.274
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-15 15:44:08.276
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-15 15:44:08.278
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-15 15:44:08.278
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-15 15:44:09.167
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-15 15:44:09.640
Rithmic Trading | Received logon response. | 2020-06-15 15:44:09.640
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-15 15:44:09.640
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-15 15:44:09.640
Rithmic Trading | Logon error received from server | 2020-06-15 15:44:09.640
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:44:09.640
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:09.640
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:44:09.671
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-15 15:44:09.671
Rithmic Trading | Disconnected. | 2020-06-15 15:44:09.671
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:09.671
Rithmic Trading | Port for executable: 55884 | 2020-06-15 15:44:11.658
Listening socket (1092). Port 55884 | Closed. | 2020-06-15 15:44:11.658
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:44:11.659
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55884. Current folder: C:\SierraChart\Rim | 2020-06-15 15:44:11.712
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:44:13.705
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55884 | 2020-06-15 15:44:13.705
DTC Client socket (2) | Creating socket. | 2020-06-15 15:44:13.705
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:44:13.705
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:44:15.709 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:44:15.709
DTC Client socket (2) | Closed. | 2020-06-15 15:44:15.709
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:44:15.709
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:15.709
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:44:15.719
Rithmic Trading | Disconnected. | 2020-06-15 15:44:15.719
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:15.719
Rithmic Trading | Port for executable: 55886 | 2020-06-15 15:44:17.722
Listening socket (1568). Port 55886 | Closed. | 2020-06-15 15:44:17.722
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:44:17.723
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55886. Current folder: C:\SierraChart\Rim | 2020-06-15 15:44:17.766
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:44:19.760
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55886 | 2020-06-15 15:44:19.760
DTC Client socket (2) | Creating socket. | 2020-06-15 15:44:19.760
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:44:19.760
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:44:21.763 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:44:21.763
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:44:21.763
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:21.763
DTC Client socket (2) | Closed. | 2020-06-15 15:44:21.763
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:44:21.767
Rithmic Trading | Disconnected. | 2020-06-15 15:44:21.767
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:21.767
Rithmic Trading | Port for executable: 55888 | 2020-06-15 15:44:23.769
Listening socket (1544). Port 55888 | Closed. | 2020-06-15 15:44:23.770
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:44:23.770
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55888. Current folder: C:\SierraChart\Rim | 2020-06-15 15:44:23.812
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:44:25.798
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55888 | 2020-06-15 15:44:25.798
DTC Client socket (2) | Creating socket. | 2020-06-15 15:44:25.798
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:44:25.798
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:44:27.801 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:44:27.801
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:44:27.801
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:27.801
DTC Client socket (2) | Closed. | 2020-06-15 15:44:27.801
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:44:27.823
Rithmic Trading | Disconnected. | 2020-06-15 15:44:27.823
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:27.823
Rithmic Trading | Port for executable: 55890 | 2020-06-15 15:44:29.815
Listening socket (1512). Port 55890 | Closed. | 2020-06-15 15:44:29.815
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:44:29.815
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55890. Current folder: C:\SierraChart\Rim | 2020-06-15 15:44:29.857
DTC Client socket (1) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2020-06-15 15:44:31.367 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-15 15:44:31.367
DTC Client socket (1) | Closed. | 2020-06-15 15:44:31.367
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:44:31.846
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55890 | 2020-06-15 15:44:31.846
DTC Client socket (1) | Creating socket. | 2020-06-15 15:44:31.846
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:44:31.846
DTC Client socket (1) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:44:33.851 *
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:44:33.851
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:44:33.851
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:33.851
DTC Client socket (1) | Closed. | 2020-06-15 15:44:33.851
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:44:33.861
Rithmic Trading | Disconnected. | 2020-06-15 15:44:33.861
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:33.861
Rithmic Trading | Port for executable: 55892 | 2020-06-15 15:44:35.864
Listening socket (1572). Port 55892 | Closed. | 2020-06-15 15:44:35.864
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:44:35.865
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55892. Current folder: C:\SierraChart\Rim | 2020-06-15 15:44:35.907
Rithmic Trading | Bridge process is running. | 2020-06-15 15:44:37.907
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55892 | 2020-06-15 15:44:37.907
DTC Client socket (1) | Creating socket. | 2020-06-15 15:44:37.907
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:44:37.907
Rithmic Trading | Connected to server. | 2020-06-15 15:44:37.908
Rithmic Trading | Starting socket receive thread. | 2020-06-15 15:44:37.908
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-15 15:44:37.910
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-15 15:44:37.911
Rithmic Trading | Sending logon request message. | 2020-06-15 15:44:37.911
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-15 15:44:37.912
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-15 15:44:37.914
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-15 15:44:37.914
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-15 15:44:38.801
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-15 15:44:39.281
Rithmic Trading | Received logon response. | 2020-06-15 15:44:39.281
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-15 15:44:39.281
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-15 15:44:39.281
Rithmic Trading | Logon error received from server | 2020-06-15 15:44:39.281
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:44:39.281
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:39.281
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:44:39.304
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-15 15:44:39.304
Rithmic Trading | Disconnected. | 2020-06-15 15:44:39.304
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:39.304
Rithmic Trading | Port for executable: 55906 | 2020-06-15 15:44:41.303
Listening socket (1512). Port 55906 | Closed. | 2020-06-15 15:44:41.303
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:44:41.304
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55906. Current folder: C:\SierraChart\Rim | 2020-06-15 15:44:41.345
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:44:43.344
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55906 | 2020-06-15 15:44:43.344
DTC Client socket (2) | Creating socket. | 2020-06-15 15:44:43.344
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:44:43.344
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:44:45.348 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:44:45.348
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:44:45.348
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:45.348
DTC Client socket (2) | Closed. | 2020-06-15 15:44:45.348
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:44:45.370
Rithmic Trading | Disconnected. | 2020-06-15 15:44:45.370
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:45.370
Rithmic Trading | Port for executable: 55908 | 2020-06-15 15:44:47.373
Listening socket (1592). Port 55908 | Closed. | 2020-06-15 15:44:47.373
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:44:47.373
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55908. Current folder: C:\SierraChart\Rim | 2020-06-15 15:44:47.413
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:44:49.407
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55908 | 2020-06-15 15:44:49.407
DTC Client socket (2) | Creating socket. | 2020-06-15 15:44:49.407
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:44:49.407
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:44:51.411 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:44:51.411
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:44:51.411
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:51.411
DTC Client socket (2) | Closed. | 2020-06-15 15:44:51.411
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:44:51.422
Rithmic Trading | Disconnected. | 2020-06-15 15:44:51.423
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:51.423
Rithmic Trading | Port for executable: 55910 | 2020-06-15 15:44:53.426
Listening socket (1100). Port 55910 | Closed. | 2020-06-15 15:44:53.426
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:44:53.427
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55910. Current folder: C:\SierraChart\Rim | 2020-06-15 15:44:53.466
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:44:55.455
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55910 | 2020-06-15 15:44:55.455
DTC Client socket (2) | Creating socket. | 2020-06-15 15:44:55.455
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:44:55.456
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:44:57.457 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:44:57.458
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:44:57.458
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:57.458
DTC Client socket (2) | Closed. | 2020-06-15 15:44:57.458
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:44:57.471
Rithmic Trading | Disconnected. | 2020-06-15 15:44:57.471
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:44:57.471
Rithmic Trading | Port for executable: 55916 | 2020-06-15 15:44:59.474
Listening socket (1572). Port 55916 | Closed. | 2020-06-15 15:44:59.474
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:44:59.475
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55916. Current folder: C:\SierraChart\Rim | 2020-06-15 15:44:59.515
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-15 15:45:00.988
DTC Client socket (1) | Closed. | 2020-06-15 15:45:00.988
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:45:01.513
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55916 | 2020-06-15 15:45:01.513
DTC Client socket (1) | Creating socket. | 2020-06-15 15:45:01.513
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:45:01.513
DTC Client socket (1) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:45:03.516 *
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:45:03.517
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:45:03.517
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:03.517
DTC Client socket (1) | Closed. | 2020-06-15 15:45:03.517
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:45:03.537
Rithmic Trading | Disconnected. | 2020-06-15 15:45:03.537
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:03.537
Rithmic Trading | Port for executable: 55918 | 2020-06-15 15:45:05.543
Listening socket (1544). Port 55918 | Closed. | 2020-06-15 15:45:05.543
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:45:05.544
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55918. Current folder: C:\SierraChart\Rim | 2020-06-15 15:45:05.586
Rithmic Trading | Bridge process is running. | 2020-06-15 15:45:07.580
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55918 | 2020-06-15 15:45:07.580
DTC Client socket (1) | Creating socket. | 2020-06-15 15:45:07.581
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:45:07.581
Rithmic Trading | Connected to server. | 2020-06-15 15:45:07.582
Rithmic Trading | Starting socket receive thread. | 2020-06-15 15:45:07.582
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-15 15:45:07.583
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-15 15:45:07.584
Rithmic Trading | Sending logon request message. | 2020-06-15 15:45:07.584
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-15 15:45:07.585
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-15 15:45:07.587
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-15 15:45:07.587
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-15 15:45:08.485
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-15 15:45:08.956
Rithmic Trading | Received logon response. | 2020-06-15 15:45:08.956
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-15 15:45:08.956
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-15 15:45:08.956
Rithmic Trading | Logon error received from server | 2020-06-15 15:45:08.956
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:45:08.956
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:08.956
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:45:08.978
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-15 15:45:08.978
Rithmic Trading | Disconnected. | 2020-06-15 15:45:08.978
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:08.978
Rithmic Trading | Port for executable: 55932 | 2020-06-15 15:45:10.972
Listening socket (1596). Port 55932 | Closed. | 2020-06-15 15:45:10.972
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:45:10.973
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55932. Current folder: C:\SierraChart\Rim | 2020-06-15 15:45:11.016
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:45:13.015
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55932 | 2020-06-15 15:45:13.015
DTC Client socket (2) | Creating socket. | 2020-06-15 15:45:13.016
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:45:13.016
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:45:15.019 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:45:15.019
DTC Client socket (2) | Closed. | 2020-06-15 15:45:15.019
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:45:15.019
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:15.019
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:45:15.040
Rithmic Trading | Disconnected. | 2020-06-15 15:45:15.040
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:15.040
Rithmic Trading | Port for executable: 55934 | 2020-06-15 15:45:17.034
Listening socket (772). Port 55934 | Closed. | 2020-06-15 15:45:17.034
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:45:17.034
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55934. Current folder: C:\SierraChart\Rim | 2020-06-15 15:45:17.079
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:45:19.082
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55934 | 2020-06-15 15:45:19.082
DTC Client socket (2) | Creating socket. | 2020-06-15 15:45:19.082
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:45:19.082
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:45:21.086 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:45:21.086
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:45:21.086
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:21.086
DTC Client socket (2) | Closed. | 2020-06-15 15:45:21.086
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:45:21.097
Rithmic Trading | Disconnected. | 2020-06-15 15:45:21.097
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:21.097
Rithmic Trading | Port for executable: 55936 | 2020-06-15 15:45:23.099
Listening socket (1572). Port 55936 | Closed. | 2020-06-15 15:45:23.099
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:45:23.100
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55936. Current folder: C:\SierraChart\Rim | 2020-06-15 15:45:23.144
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:45:25.143
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55936 | 2020-06-15 15:45:25.143
DTC Client socket (2) | Creating socket. | 2020-06-15 15:45:25.143
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:45:25.144
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:45:27.147 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:45:27.147
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:45:27.147
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:27.147
DTC Client socket (2) | Closed. | 2020-06-15 15:45:27.147
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:45:27.157
Rithmic Trading | Disconnected. | 2020-06-15 15:45:27.157
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:27.157
Rithmic Trading | Port for executable: 55938 | 2020-06-15 15:45:29.161
Listening socket (1092). Port 55938 | Closed. | 2020-06-15 15:45:29.161
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:45:29.162
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55938. Current folder: C:\SierraChart\Rim | 2020-06-15 15:45:29.204
DTC Client socket (1) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2020-06-15 15:45:30.670 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-15 15:45:30.670
DTC Client socket (1) | Closed. | 2020-06-15 15:45:30.670
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:45:31.210
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55938 | 2020-06-15 15:45:31.210
DTC Client socket (1) | Creating socket. | 2020-06-15 15:45:31.210
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:45:31.210
DTC Client socket (1) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:45:33.213 *
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:45:33.213
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:45:33.214
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:33.214
DTC Client socket (1) | Closed. | 2020-06-15 15:45:33.214
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:45:33.224
Rithmic Trading | Disconnected. | 2020-06-15 15:45:33.224
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:33.224
Rithmic Trading | Port for executable: 55940 | 2020-06-15 15:45:35.233
Listening socket (1572). Port 55940 | Closed. | 2020-06-15 15:45:35.233
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:45:35.233
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55940. Current folder: C:\SierraChart\Rim | 2020-06-15 15:45:35.275
Rithmic Trading | Bridge process is running. | 2020-06-15 15:45:37.267
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55940 | 2020-06-15 15:45:37.267
DTC Client socket (1) | Creating socket. | 2020-06-15 15:45:37.267
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:45:37.267
Rithmic Trading | Connected to server. | 2020-06-15 15:45:37.269
Rithmic Trading | Starting socket receive thread. | 2020-06-15 15:45:37.269
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-15 15:45:37.271
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-15 15:45:37.272
Rithmic Trading | Sending logon request message. | 2020-06-15 15:45:37.272
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-15 15:45:37.273
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-15 15:45:37.276
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-15 15:45:37.276
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-15 15:45:38.206
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-15 15:45:38.707
Rithmic Trading | Received logon response. | 2020-06-15 15:45:38.707
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-15 15:45:38.707
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-15 15:45:38.707
Rithmic Trading | Logon error received from server | 2020-06-15 15:45:38.707
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:45:38.707
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:38.707
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:45:38.720
Rithmic Trading | Disconnected. | 2020-06-15 15:45:38.720
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:38.720
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-15 15:45:38.720
Rithmic Trading | Port for executable: 55959 | 2020-06-15 15:45:40.720
Listening socket (1092). Port 55959 | Closed. | 2020-06-15 15:45:40.720
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:45:40.721
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55959. Current folder: C:\SierraChart\Rim | 2020-06-15 15:45:40.760
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:45:42.751
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55959 | 2020-06-15 15:45:42.751
DTC Client socket (2) | Creating socket. | 2020-06-15 15:45:42.752
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:45:42.752
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:45:44.755 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:45:44.755
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:45:44.755
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:44.755
DTC Client socket (2) | Closed. | 2020-06-15 15:45:44.755
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:45:44.766
Rithmic Trading | Disconnected. | 2020-06-15 15:45:44.766
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:44.766
Rithmic Trading | Port for executable: 55961 | 2020-06-15 15:45:46.770
Listening socket (1100). Port 55961 | Closed. | 2020-06-15 15:45:46.770
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:45:46.771
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55961. Current folder: C:\SierraChart\Rim | 2020-06-15 15:45:46.811
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:45:48.798
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55961 | 2020-06-15 15:45:48.798
DTC Client socket (2) | Creating socket. | 2020-06-15 15:45:48.798
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:45:48.798
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:45:50.800 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:45:50.800
DTC Client socket (2) | Closed. | 2020-06-15 15:45:50.800
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:45:50.800
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:50.800
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:45:50.821
Rithmic Trading | Disconnected. | 2020-06-15 15:45:50.822
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:50.822
Rithmic Trading | Port for executable: 55963 | 2020-06-15 15:45:52.819
Listening socket (1124). Port 55963 | Closed. | 2020-06-15 15:45:52.819
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:45:52.820
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55963. Current folder: C:\SierraChart\Rim | 2020-06-15 15:45:52.860
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:45:54.861
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55963 | 2020-06-15 15:45:54.861
DTC Client socket (3) | Creating socket. | 2020-06-15 15:45:54.861
DTC Client socket (3) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:45:54.862
DTC Client socket (3) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:45:56.866 *
DTC Client socket (3) | CloseSocket call. | 2020-06-15 15:45:56.866
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:45:56.866
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:56.866
DTC Client socket (3) | Closed. | 2020-06-15 15:45:56.866
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:45:56.876
Rithmic Trading | Disconnected. | 2020-06-15 15:45:56.876
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:45:56.876
Rithmic Trading | Port for executable: 55968 | 2020-06-15 15:45:58.889
Listening socket (1572). Port 55968 | Closed. | 2020-06-15 15:45:58.889
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:45:58.889
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55968. Current folder: C:\SierraChart\Rim | 2020-06-15 15:45:58.929
DTC Client socket (1) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2020-06-15 15:46:00.366 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-15 15:46:00.366
DTC Client socket (1) | Closed. | 2020-06-15 15:46:00.366
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:46:00.931
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55968 | 2020-06-15 15:46:00.931
DTC Client socket (1) | Creating socket. | 2020-06-15 15:46:00.931
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:46:00.931
DTC Client socket (1) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:46:02.935 *
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:46:02.935
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:46:02.935
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:02.935
DTC Client socket (1) | Closed. | 2020-06-15 15:46:02.935
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:46:02.945
Rithmic Trading | Disconnected. | 2020-06-15 15:46:02.945
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:02.945
Rithmic Trading | Port for executable: 55970 | 2020-06-15 15:46:04.947
Listening socket (1592). Port 55970 | Closed. | 2020-06-15 15:46:04.947
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:46:04.947
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55970. Current folder: C:\SierraChart\Rim | 2020-06-15 15:46:04.985
Rithmic Trading | Bridge process is running. | 2020-06-15 15:46:06.987
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55970 | 2020-06-15 15:46:06.987
DTC Client socket (1) | Creating socket. | 2020-06-15 15:46:06.987
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:46:06.987
Rithmic Trading | Connected to server. | 2020-06-15 15:46:06.988
Rithmic Trading | Starting socket receive thread. | 2020-06-15 15:46:06.989
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-15 15:46:06.990
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-15 15:46:06.991
Rithmic Trading | Sending logon request message. | 2020-06-15 15:46:06.991
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-15 15:46:06.991
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-15 15:46:06.993
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-15 15:46:06.993
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-15 15:46:07.878
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-15 15:46:08.358
Rithmic Trading | Received logon response. | 2020-06-15 15:46:08.359
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-15 15:46:08.359
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-15 15:46:08.359
Rithmic Trading | Logon error received from server | 2020-06-15 15:46:08.359
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:46:08.359
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:08.359
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:46:08.363
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-15 15:46:08.363
Rithmic Trading | Disconnected. | 2020-06-15 15:46:08.363
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:08.363
Rithmic Trading | Port for executable: 55984 | 2020-06-15 15:46:10.363
Listening socket (1556). Port 55984 | Closed. | 2020-06-15 15:46:10.363
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:46:10.364
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55984. Current folder: C:\SierraChart\Rim | 2020-06-15 15:46:10.403
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:46:12.395
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55984 | 2020-06-15 15:46:12.395
DTC Client socket (2) | Creating socket. | 2020-06-15 15:46:12.395
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:46:12.396
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:46:14.400 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:46:14.400
DTC Client socket (2) | Closed. | 2020-06-15 15:46:14.400
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:46:14.400
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:14.400
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:46:14.411
Rithmic Trading | Disconnected. | 2020-06-15 15:46:14.411
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:14.411
Rithmic Trading | Port for executable: 55987 | 2020-06-15 15:46:16.411
Listening socket (1568). Port 55987 | Closed. | 2020-06-15 15:46:16.411
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:46:16.411
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55987. Current folder: C:\SierraChart\Rim | 2020-06-15 15:46:16.454
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:46:18.455
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55987 | 2020-06-15 15:46:18.455
DTC Client socket (2) | Creating socket. | 2020-06-15 15:46:18.455
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:46:18.455
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:46:20.457 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:46:20.458
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:46:20.458
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:20.458
DTC Client socket (2) | Closed. | 2020-06-15 15:46:20.458
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:46:20.479
Rithmic Trading | Disconnected. | 2020-06-15 15:46:20.479
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:20.479
Rithmic Trading | Port for executable: 55989 | 2020-06-15 15:46:22.472
Listening socket (1128). Port 55989 | Closed. | 2020-06-15 15:46:22.473
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:46:22.474
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55989. Current folder: C:\SierraChart\Rim | 2020-06-15 15:46:22.516
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:46:24.502
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55989 | 2020-06-15 15:46:24.502
DTC Client socket (2) | Creating socket. | 2020-06-15 15:46:24.502
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:46:24.502
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:46:26.505 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:46:26.505
DTC Client socket (2) | Closed. | 2020-06-15 15:46:26.506
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:46:26.506
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:26.506
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:46:26.517
Rithmic Trading | Disconnected. | 2020-06-15 15:46:26.517
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:26.517
Rithmic Trading | Port for executable: 55991 | 2020-06-15 15:46:28.529
Listening socket (1092). Port 55991 | Closed. | 2020-06-15 15:46:28.529
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:46:28.531
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55991. Current folder: C:\SierraChart\Rim | 2020-06-15 15:46:28.572
DTC Client socket (1) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2020-06-15 15:46:30.075 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-15 15:46:30.075
DTC Client socket (1) | Closed. | 2020-06-15 15:46:30.075
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:46:30.563
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55991 | 2020-06-15 15:46:30.563
DTC Client socket (1) | Creating socket. | 2020-06-15 15:46:30.563
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:46:30.563
DTC Client socket (1) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:46:32.567 *
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:46:32.567
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:46:32.567
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:32.567
DTC Client socket (1) | Closed. | 2020-06-15 15:46:32.567
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:46:32.578
Rithmic Trading | Disconnected. | 2020-06-15 15:46:32.579
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:32.579
Rithmic Trading | Port for executable: 55993 | 2020-06-15 15:46:34.583
Listening socket (1128). Port 55993 | Closed. | 2020-06-15 15:46:34.583
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:46:34.584
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:55993. Current folder: C:\SierraChart\Rim | 2020-06-15 15:46:34.633
Rithmic Trading | Bridge process is running. | 2020-06-15 15:46:36.626
Rithmic Trading | Connecting to the server 127.0.0.1. Port 55993 | 2020-06-15 15:46:36.626
DTC Client socket (1) | Creating socket. | 2020-06-15 15:46:36.626
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:46:36.626
Rithmic Trading | Connected to server. | 2020-06-15 15:46:36.627
Rithmic Trading | Starting socket receive thread. | 2020-06-15 15:46:36.627
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-15 15:46:36.629
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-15 15:46:36.630
Rithmic Trading | Sending logon request message. | 2020-06-15 15:46:36.630
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-15 15:46:36.631
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-15 15:46:36.632
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-15 15:46:36.632
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-15 15:46:37.552
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-15 15:46:38.022
Rithmic Trading | Received logon response. | 2020-06-15 15:46:38.022
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-15 15:46:38.022
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-15 15:46:38.022
Rithmic Trading | Logon error received from server | 2020-06-15 15:46:38.022
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:46:38.022
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:38.022
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:46:38.033
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-15 15:46:38.033
Rithmic Trading | Disconnected. | 2020-06-15 15:46:38.033
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:38.033
Rithmic Trading | Port for executable: 56007 | 2020-06-15 15:46:40.035
Listening socket (1556). Port 56007 | Closed. | 2020-06-15 15:46:40.035
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:46:40.035
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56007. Current folder: C:\SierraChart\Rim | 2020-06-15 15:46:40.081
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:46:42.079
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56007 | 2020-06-15 15:46:42.079
DTC Client socket (2) | Creating socket. | 2020-06-15 15:46:42.079
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:46:42.080
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:46:44.083 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:46:44.084
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:46:44.084
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:44.084
DTC Client socket (2) | Closed. | 2020-06-15 15:46:44.084
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:46:44.094
Rithmic Trading | Disconnected. | 2020-06-15 15:46:44.094
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:44.094
Rithmic Trading | Port for executable: 56009 | 2020-06-15 15:46:46.098
Listening socket (1604). Port 56009 | Closed. | 2020-06-15 15:46:46.098
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:46:46.098
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56009. Current folder: C:\SierraChart\Rim | 2020-06-15 15:46:46.138
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:46:48.126
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56009 | 2020-06-15 15:46:48.126
DTC Client socket (2) | Creating socket. | 2020-06-15 15:46:48.126
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:46:48.126
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:46:50.129 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:46:50.129
DTC Client socket (2) | Closed. | 2020-06-15 15:46:50.129
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:46:50.129
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:50.129
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:46:50.149
Rithmic Trading | Disconnected. | 2020-06-15 15:46:50.150
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:50.150
Rithmic Trading | Port for executable: 56011 | 2020-06-15 15:46:52.147
Listening socket (1600). Port 56011 | Closed. | 2020-06-15 15:46:52.147
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:46:52.147
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56011. Current folder: C:\SierraChart\Rim | 2020-06-15 15:46:52.189
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:46:54.190
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56011 | 2020-06-15 15:46:54.190
DTC Client socket (2) | Creating socket. | 2020-06-15 15:46:54.191
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:46:54.191
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:46:56.192 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:46:56.192
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:46:56.192
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:56.192
DTC Client socket (2) | Closed. | 2020-06-15 15:46:56.192
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:46:56.203
Rithmic Trading | Disconnected. | 2020-06-15 15:46:56.203
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:46:56.203
Rithmic Trading | Port for executable: 56020 | 2020-06-15 15:46:58.213
Listening socket (1548). Port 56020 | Closed. | 2020-06-15 15:46:58.213
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:46:58.214
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56020. Current folder: C:\SierraChart\Rim | 2020-06-15 15:46:58.259
DTC Client socket (1) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2020-06-15 15:46:59.733 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-15 15:46:59.733
DTC Client socket (1) | Closed. | 2020-06-15 15:46:59.733
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:47:00.255
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56020 | 2020-06-15 15:47:00.255
DTC Client socket (1) | Creating socket. | 2020-06-15 15:47:00.255
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:47:00.255
DTC Client socket (1) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:47:02.259 *
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:47:02.259
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:47:02.259
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:02.259
DTC Client socket (1) | Closed. | 2020-06-15 15:47:02.259
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:47:02.270
Rithmic Trading | Disconnected. | 2020-06-15 15:47:02.270
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:02.270
Rithmic Trading | Port for executable: 56023 | 2020-06-15 15:47:04.270
Listening socket (1560). Port 56023 | Closed. | 2020-06-15 15:47:04.270
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:47:04.271
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56023. Current folder: C:\SierraChart\Rim | 2020-06-15 15:47:04.310
Rithmic Trading | Bridge process is running. | 2020-06-15 15:47:06.310
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56023 | 2020-06-15 15:47:06.310
DTC Client socket (1) | Creating socket. | 2020-06-15 15:47:06.310
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:47:06.310
Rithmic Trading | Connected to server. | 2020-06-15 15:47:06.312
Rithmic Trading | Starting socket receive thread. | 2020-06-15 15:47:06.312
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-15 15:47:06.314
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-15 15:47:06.315
Rithmic Trading | Sending logon request message. | 2020-06-15 15:47:06.315
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-15 15:47:06.316
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-15 15:47:06.318
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-15 15:47:06.318
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-15 15:47:07.222
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-15 15:47:07.684
Rithmic Trading | Received logon response. | 2020-06-15 15:47:07.684
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-15 15:47:07.684
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-15 15:47:07.684
Rithmic Trading | Logon error received from server | 2020-06-15 15:47:07.684
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:47:07.684
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:07.684
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:47:07.690
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-15 15:47:07.690
Rithmic Trading | Disconnected. | 2020-06-15 15:47:07.690
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:07.690
Rithmic Trading | Port for executable: 56037 | 2020-06-15 15:47:09.690
Listening socket (1124). Port 56037 | Closed. | 2020-06-15 15:47:09.691
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:47:09.691
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56037. Current folder: C:\SierraChart\Rim | 2020-06-15 15:47:09.735
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:47:11.739
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56037 | 2020-06-15 15:47:11.739
DTC Client socket (2) | Creating socket. | 2020-06-15 15:47:11.739
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:47:11.739
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:47:13.751 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:47:13.751
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:47:13.751
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:13.751
DTC Client socket (2) | Closed. | 2020-06-15 15:47:13.751
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:47:13.773
Rithmic Trading | Disconnected. | 2020-06-15 15:47:13.773
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:13.773
Rithmic Trading | Port for executable: 56040 | 2020-06-15 15:47:15.774
Listening socket (1560). Port 56040 | Closed. | 2020-06-15 15:47:15.774
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:47:15.774
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56040. Current folder: C:\SierraChart\Rim | 2020-06-15 15:47:15.816
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:47:17.814
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56040 | 2020-06-15 15:47:17.814
DTC Client socket (2) | Creating socket. | 2020-06-15 15:47:17.814
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:47:17.814
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:47:19.816 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:47:19.816
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:47:19.816
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:19.816
DTC Client socket (2) | Closed. | 2020-06-15 15:47:19.816
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:47:19.837
Rithmic Trading | Disconnected. | 2020-06-15 15:47:19.837
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:19.837
Rithmic Trading | Port for executable: 56042 | 2020-06-15 15:47:21.838
Listening socket (1524). Port 56042 | Closed. | 2020-06-15 15:47:21.838
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:47:21.839
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56042. Current folder: C:\SierraChart\Rim | 2020-06-15 15:47:21.884
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:47:23.878
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56042 | 2020-06-15 15:47:23.878
DTC Client socket (2) | Creating socket. | 2020-06-15 15:47:23.878
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:47:23.878
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:47:25.881 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:47:25.881
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:47:25.881
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:25.881
DTC Client socket (2) | Closed. | 2020-06-15 15:47:25.881
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:47:25.892
Rithmic Trading | Disconnected. | 2020-06-15 15:47:25.892
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:25.892
Rithmic Trading | Port for executable: 56053 | 2020-06-15 15:47:27.900
Listening socket (1124). Port 56053 | Closed. | 2020-06-15 15:47:27.901
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:47:27.901
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56053. Current folder: C:\SierraChart\Rim | 2020-06-15 15:47:27.939
DTC Client socket (1) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2020-06-15 15:47:29.398 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-15 15:47:29.398
DTC Client socket (1) | Closed. | 2020-06-15 15:47:29.398
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:47:29.946
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56053 | 2020-06-15 15:47:29.946
DTC Client socket (1) | Creating socket. | 2020-06-15 15:47:29.946
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:47:29.946
DTC Client socket (1) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:47:31.950 *
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:47:31.951
DTC Client socket (1) | Closed. | 2020-06-15 15:47:31.951
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:47:31.951
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:31.951
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:47:31.961
Rithmic Trading | Disconnected. | 2020-06-15 15:47:31.961
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:31.962
Rithmic Trading | Port for executable: 56058 | 2020-06-15 15:47:33.958
Listening socket (1524). Port 56058 | Closed. | 2020-06-15 15:47:33.958
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:47:33.958
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56058. Current folder: C:\SierraChart\Rim | 2020-06-15 15:47:33.999
Rithmic Trading | Bridge process is running. | 2020-06-15 15:47:35.984
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56058 | 2020-06-15 15:47:35.984
DTC Client socket (1) | Creating socket. | 2020-06-15 15:47:35.984
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:47:35.984
Rithmic Trading | Connected to server. | 2020-06-15 15:47:35.986
Rithmic Trading | Starting socket receive thread. | 2020-06-15 15:47:35.986
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-15 15:47:35.987
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-15 15:47:35.988
Rithmic Trading | Sending logon request message. | 2020-06-15 15:47:35.988
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-15 15:47:35.988
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-15 15:47:35.991
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-15 15:47:35.991
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-15 15:47:36.877
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-15 15:47:37.336
Rithmic Trading | Received logon response. | 2020-06-15 15:47:37.336
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-15 15:47:37.336
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-15 15:47:37.336
Rithmic Trading | Logon error received from server | 2020-06-15 15:47:37.336
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:47:37.336
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:37.336
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:47:37.346
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-15 15:47:37.346
Rithmic Trading | Disconnected. | 2020-06-15 15:47:37.346
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:37.346
Rithmic Trading | Port for executable: 56072 | 2020-06-15 15:47:39.348
Listening socket (1524). Port 56072 | Closed. | 2020-06-15 15:47:39.349
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:47:39.349
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56072. Current folder: C:\SierraChart\Rim | 2020-06-15 15:47:39.391
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:47:41.395
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56072 | 2020-06-15 15:47:41.395
DTC Client socket (2) | Creating socket. | 2020-06-15 15:47:41.395
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:47:41.395
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:47:43.397 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:47:43.397
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:47:43.397
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:43.397
DTC Client socket (2) | Closed. | 2020-06-15 15:47:43.397
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:47:43.407
Rithmic Trading | Disconnected. | 2020-06-15 15:47:43.407
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:43.407
Rithmic Trading | Port for executable: 56074 | 2020-06-15 15:47:45.410
Listening socket (1544). Port 56074 | Closed. | 2020-06-15 15:47:45.410
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:47:45.410
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56074. Current folder: C:\SierraChart\Rim | 2020-06-15 15:47:45.452
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:47:47.438
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56074 | 2020-06-15 15:47:47.438
DTC Client socket (2) | Creating socket. | 2020-06-15 15:47:47.438
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:47:47.438
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:47:49.439 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:47:49.439
DTC Client socket (2) | Closed. | 2020-06-15 15:47:49.439
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:47:49.439
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:49.439
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:47:49.460
Rithmic Trading | Disconnected. | 2020-06-15 15:47:49.460
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:49.460
Rithmic Trading | Port for executable: 56076 | 2020-06-15 15:47:51.463
Listening socket (1128). Port 56076 | Closed. | 2020-06-15 15:47:51.463
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:47:51.463
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56076. Current folder: C:\SierraChart\Rim | 2020-06-15 15:47:51.504
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:47:53.501
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56076 | 2020-06-15 15:47:53.501
DTC Client socket (2) | Creating socket. | 2020-06-15 15:47:53.501
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:47:53.501
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:47:55.503 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:47:55.503
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:47:55.503
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:55.503
DTC Client socket (2) | Closed. | 2020-06-15 15:47:55.503
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:47:55.524
Rithmic Trading | Disconnected. | 2020-06-15 15:47:55.524
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:47:55.524
Rithmic Trading | Port for executable: 56080 | 2020-06-15 15:47:57.524
Listening socket (1128). Port 56080 | Closed. | 2020-06-15 15:47:57.524
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:47:57.524
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56080. Current folder: C:\SierraChart\Rim | 2020-06-15 15:47:57.563
DTC Client socket (1) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2020-06-15 15:47:59.090 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-15 15:47:59.090
DTC Client socket (1) | Closed. | 2020-06-15 15:47:59.090
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:47:59.565
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56080 | 2020-06-15 15:47:59.565
DTC Client socket (1) | Creating socket. | 2020-06-15 15:47:59.565
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:47:59.565
DTC Client socket (1) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:48:01.569 *
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:48:01.569
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:48:01.569
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:01.569
DTC Client socket (1) | Closed. | 2020-06-15 15:48:01.569
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:48:01.586
Rithmic Trading | Disconnected. | 2020-06-15 15:48:01.586
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:01.586
Rithmic Trading | Port for executable: 56082 | 2020-06-15 15:48:03.584
Listening socket (1100). Port 56082 | Closed. | 2020-06-15 15:48:03.584
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:48:03.585
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56082. Current folder: C:\SierraChart\Rim | 2020-06-15 15:48:03.624
Rithmic Trading | Bridge process is running. | 2020-06-15 15:48:05.615
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56082 | 2020-06-15 15:48:05.615
DTC Client socket (1) | Creating socket. | 2020-06-15 15:48:05.616
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:48:05.616
Rithmic Trading | Connected to server. | 2020-06-15 15:48:05.618
Rithmic Trading | Starting socket receive thread. | 2020-06-15 15:48:05.618
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-15 15:48:05.619
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-15 15:48:05.619
Rithmic Trading | Sending logon request message. | 2020-06-15 15:48:05.619
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-15 15:48:05.620
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-15 15:48:05.623
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-15 15:48:05.623
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-15 15:48:06.499
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-15 15:48:06.960
Rithmic Trading | Received logon response. | 2020-06-15 15:48:06.961
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-15 15:48:06.961
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-15 15:48:06.961
Rithmic Trading | Logon error received from server | 2020-06-15 15:48:06.961
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:48:06.961
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:06.961
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:48:06.971
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-15 15:48:06.971
Rithmic Trading | Disconnected. | 2020-06-15 15:48:06.972
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:06.972
Rithmic Trading | Port for executable: 56097 | 2020-06-15 15:48:08.974
Listening socket (1600). Port 56097 | Closed. | 2020-06-15 15:48:08.975
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:48:08.975
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56097. Current folder: C:\SierraChart\Rim | 2020-06-15 15:48:09.017
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:48:11.017
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56097 | 2020-06-15 15:48:11.017
DTC Client socket (2) | Creating socket. | 2020-06-15 15:48:11.017
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:48:11.017
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:48:13.020 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:48:13.020
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:48:13.020
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:13.020
DTC Client socket (2) | Closed. | 2020-06-15 15:48:13.020
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:48:13.031
Rithmic Trading | Disconnected. | 2020-06-15 15:48:13.031
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:13.031
Rithmic Trading | Port for executable: 56099 | 2020-06-15 15:48:15.036
Listening socket (1620). Port 56099 | Closed. | 2020-06-15 15:48:15.036
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:48:15.037
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56099. Current folder: C:\SierraChart\Rim | 2020-06-15 15:48:15.079
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:48:17.086
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56099 | 2020-06-15 15:48:17.086
DTC Client socket (2) | Creating socket. | 2020-06-15 15:48:17.086
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:48:17.086
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:48:19.089 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:48:19.089
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:48:19.089
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:19.089
DTC Client socket (2) | Closed. | 2020-06-15 15:48:19.089
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:48:19.100
Rithmic Trading | Disconnected. | 2020-06-15 15:48:19.100
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:19.100
Rithmic Trading | Port for executable: 56101 | 2020-06-15 15:48:21.097
Listening socket (1624). Port 56101 | Closed. | 2020-06-15 15:48:21.097
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:48:21.097
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56101. Current folder: C:\SierraChart\Rim | 2020-06-15 15:48:21.136
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:48:23.126
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56101 | 2020-06-15 15:48:23.126
DTC Client socket (2) | Creating socket. | 2020-06-15 15:48:23.126
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:48:23.126
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:48:25.130 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:48:25.130
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:48:25.130
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:25.130
DTC Client socket (2) | Closed. | 2020-06-15 15:48:25.130
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:48:25.151
Rithmic Trading | Disconnected. | 2020-06-15 15:48:25.151
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:25.151
Rithmic Trading | Port for executable: 56103 | 2020-06-15 15:48:27.151
Listening socket (1640). Port 56103 | Closed. | 2020-06-15 15:48:27.151
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:48:27.153
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56103. Current folder: C:\SierraChart\Rim | 2020-06-15 15:48:27.192
DTC Client socket (1) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2020-06-15 15:48:28.717 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-15 15:48:28.717
DTC Client socket (1) | Closed. | 2020-06-15 15:48:28.718
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:48:29.192
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56103 | 2020-06-15 15:48:29.192
DTC Client socket (1) | Creating socket. | 2020-06-15 15:48:29.192
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:48:29.192
DTC Client socket (1) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:48:31.196 *
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:48:31.196
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:48:31.196
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:31.196
DTC Client socket (1) | Closed. | 2020-06-15 15:48:31.196
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:48:31.209
Rithmic Trading | Disconnected. | 2020-06-15 15:48:31.209
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:31.209
Rithmic Trading | Port for executable: 56111 | 2020-06-15 15:48:33.208
Listening socket (1640). Port 56111 | Closed. | 2020-06-15 15:48:33.209
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:48:33.209
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56111. Current folder: C:\SierraChart\Rim | 2020-06-15 15:48:33.247
Rithmic Trading | Bridge process is running. | 2020-06-15 15:48:35.242
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56111 | 2020-06-15 15:48:35.242
DTC Client socket (1) | Creating socket. | 2020-06-15 15:48:35.242
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:48:35.242
Rithmic Trading | Connected to server. | 2020-06-15 15:48:35.244
Rithmic Trading | Starting socket receive thread. | 2020-06-15 15:48:35.244
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-15 15:48:35.245
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-15 15:48:35.246
Rithmic Trading | Sending logon request message. | 2020-06-15 15:48:35.246
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-15 15:48:35.247
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-15 15:48:35.249
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-15 15:48:35.249
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-15 15:48:36.127
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-15 15:48:36.596
Rithmic Trading | Received logon response. | 2020-06-15 15:48:36.596
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-15 15:48:36.596
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-15 15:48:36.596
Rithmic Trading | Logon error received from server | 2020-06-15 15:48:36.596
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:48:36.596
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:36.596
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:48:36.618
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-15 15:48:36.618
Rithmic Trading | Disconnected. | 2020-06-15 15:48:36.618
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:36.618
Rithmic Trading | Port for executable: 56125 | 2020-06-15 15:48:38.614
Listening socket (1596). Port 56125 | Closed. | 2020-06-15 15:48:38.614
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:48:38.615
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56125. Current folder: C:\SierraChart\Rim | 2020-06-15 15:48:38.652
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:48:40.643
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56125 | 2020-06-15 15:48:40.643
DTC Client socket (2) | Creating socket. | 2020-06-15 15:48:40.643
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:48:40.643
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:48:42.644 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:48:42.644
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:48:42.644
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:42.644
DTC Client socket (2) | Closed. | 2020-06-15 15:48:42.644
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:48:42.665
Rithmic Trading | Disconnected. | 2020-06-15 15:48:42.665
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:42.665
Rithmic Trading | Port for executable: 56127 | 2020-06-15 15:48:44.662
Listening socket (1632). Port 56127 | Closed. | 2020-06-15 15:48:44.662
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:48:44.663
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56127. Current folder: C:\SierraChart\Rim | 2020-06-15 15:48:44.707
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:48:46.709
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56127 | 2020-06-15 15:48:46.709
DTC Client socket (2) | Creating socket. | 2020-06-15 15:48:46.709
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:48:46.709
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:48:48.711 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:48:48.711
DTC Client socket (2) | Closed. | 2020-06-15 15:48:48.711
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:48:48.711
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:48.711
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:48:48.722
Rithmic Trading | Disconnected. | 2020-06-15 15:48:48.722
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:48.722
Rithmic Trading | Port for executable: 56129 | 2020-06-15 15:48:50.722
Listening socket (1632). Port 56129 | Closed. | 2020-06-15 15:48:50.722
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:48:50.722
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56129. Current folder: C:\SierraChart\Rim | 2020-06-15 15:48:50.762
Rithmic Trading | Bridge process is not running! | 2020-06-15 15:48:52.753
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56129 | 2020-06-15 15:48:52.753
DTC Client socket (2) | Creating socket. | 2020-06-15 15:48:52.753
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:48:52.753
DTC Client socket (2) | Connect event error. Windows error code 10061: Nemohlo být vytvořeno žádné připojení, protože cílový počítač je aktivně odmítl. | 2020-06-15 15:48:54.756 *
DTC Client socket (2) | CloseSocket call. | 2020-06-15 15:48:54.757
DTC Client socket (2) | Closed. | 2020-06-15 15:48:54.757
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:48:54.757
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:54.757
DTC Client socket (0) | CloseSocket call. | 2020-06-15 15:48:54.768
Rithmic Trading | Disconnected. | 2020-06-15 15:48:54.768
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:48:54.768
DTC Client socket (1) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2020-06-15 15:48:58.341 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-15 15:48:58.341
DTC Client socket (1) | Closed. | 2020-06-15 15:48:58.341
Rithmic Trading | Port for executable: 56155 | 2020-06-15 15:50:54.783
Listening socket (1948). Port 56155 | Closed. | 2020-06-15 15:50:54.783
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:50:54.784
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56155. Current folder: C:\SierraChart\Rim | 2020-06-15 15:50:54.823
Rithmic Trading | Bridge process is running. | 2020-06-15 15:50:56.813
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56155 | 2020-06-15 15:50:56.813
DTC Client socket (1) | Creating socket. | 2020-06-15 15:50:56.813
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:50:56.813
Rithmic Trading | Connected to server. | 2020-06-15 15:50:56.814
Rithmic Trading | Starting socket receive thread. | 2020-06-15 15:50:56.814
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-15 15:50:56.815
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-15 15:50:56.816
Rithmic Trading | Sending logon request message. | 2020-06-15 15:50:56.816
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-15 15:50:56.817
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-15 15:50:56.819
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-15 15:50:56.819
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-15 15:50:57.703
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-15 15:50:58.167
Rithmic Trading | Received logon response. | 2020-06-15 15:50:58.168
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-15 15:50:58.168
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-15 15:50:58.168
Rithmic Trading | Logon error received from server | 2020-06-15 15:50:58.168
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:50:58.168
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:50:58.168
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:50:58.180
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-15 15:50:58.180
Rithmic Trading | Disconnected. | 2020-06-15 15:50:58.180
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:50:58.181
DTC Client socket (1) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2020-06-15 15:51:19.914 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-15 15:51:19.914
DTC Client socket (1) | Closed. | 2020-06-15 15:51:19.914
Rithmic Trading | Port for executable: 56211 | 2020-06-15 15:52:58.185
Listening socket (1964). Port 56211 | Closed. | 2020-06-15 15:52:58.185
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:52:58.186
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56211. Current folder: C:\SierraChart\Rim | 2020-06-15 15:52:58.230
Rithmic Trading | Bridge process is running. | 2020-06-15 15:53:00.222
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56211 | 2020-06-15 15:53:00.222
DTC Client socket (1) | Creating socket. | 2020-06-15 15:53:00.222
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:53:00.222
Rithmic Trading | Connected to server. | 2020-06-15 15:53:00.223
Rithmic Trading | Starting socket receive thread. | 2020-06-15 15:53:00.223
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-15 15:53:00.224
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-15 15:53:00.225
Rithmic Trading | Sending logon request message. | 2020-06-15 15:53:00.225
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-15 15:53:00.226
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-15 15:53:00.228
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-15 15:53:00.228
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-15 15:53:01.148
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-15 15:53:01.610
Rithmic Trading | Received logon response. | 2020-06-15 15:53:01.611
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-15 15:53:01.611
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-15 15:53:01.611
Rithmic Trading | Logon error received from server | 2020-06-15 15:53:01.611
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:53:01.611
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:53:01.611
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:53:01.639
Rithmic Trading | Disconnected. | 2020-06-15 15:53:01.639
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-15 15:53:01.639
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:53:01.639
DTC Client socket (1) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2020-06-15 15:53:23.318 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-15 15:53:23.318
DTC Client socket (1) | Closed. | 2020-06-15 15:53:23.319
Rithmic Trading | Port for executable: 56240 | 2020-06-15 15:55:01.639
Listening socket (2252). Port 56240 | Closed. | 2020-06-15 15:55:01.640
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:55:01.642
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56240. Current folder: C:\SierraChart\Rim | 2020-06-15 15:55:01.718
Rithmic Trading | Bridge process is running. | 2020-06-15 15:55:03.706
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56240 | 2020-06-15 15:55:03.706
DTC Client socket (1) | Creating socket. | 2020-06-15 15:55:03.706
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:55:03.706
Rithmic Trading | Connected to server. | 2020-06-15 15:55:03.708
Rithmic Trading | Starting socket receive thread. | 2020-06-15 15:55:03.708
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-15 15:55:03.710
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-15 15:55:03.711
Rithmic Trading | Sending logon request message. | 2020-06-15 15:55:03.711
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-15 15:55:03.712
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-15 15:55:03.714
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-15 15:55:03.714
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-15 15:55:04.615
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-15 15:55:05.083
Rithmic Trading | Received logon response. | 2020-06-15 15:55:05.083
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-15 15:55:05.083
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-15 15:55:05.083
Rithmic Trading | Logon error received from server | 2020-06-15 15:55:05.083
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:55:05.083
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:55:05.083
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:55:05.097
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-15 15:55:05.097
Rithmic Trading | Disconnected. | 2020-06-15 15:55:05.097
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:55:05.097
DTC Client socket (1) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2020-06-15 15:55:26.815 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-15 15:55:26.815
DTC Client socket (1) | Closed. | 2020-06-15 15:55:26.815
Rithmic Trading | Port for executable: 56276 | 2020-06-15 15:57:05.110
Listening socket (2004). Port 56276 | Closed. | 2020-06-15 15:57:05.110
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 15:57:05.110
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:56276. Current folder: C:\SierraChart\Rim | 2020-06-15 15:57:05.152
Rithmic Trading | Bridge process is running. | 2020-06-15 15:57:07.141
Rithmic Trading | Connecting to the server 127.0.0.1. Port 56276 | 2020-06-15 15:57:07.141
DTC Client socket (1) | Creating socket. | 2020-06-15 15:57:07.141
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 15:57:07.141
Rithmic Trading | Connected to server. | 2020-06-15 15:57:07.142
Rithmic Trading | Starting socket receive thread. | 2020-06-15 15:57:07.142
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-06-15 15:57:07.143
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-06-15 15:57:07.144
Rithmic Trading | Sending logon request message. | 2020-06-15 15:57:07.144
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-06-15 15:57:07.144
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2020-06-15 15:57:07.146
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2020-06-15 15:57:07.146
Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2020-06-15 15:57:08.021
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2020-06-15 15:57:08.477
Rithmic Trading | Received logon response. | 2020-06-15 15:57:08.477
Rithmic Trading | Server Name: DTC Bridge. | 2020-06-15 15:57:08.477
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-06-15 15:57:08.477
Rithmic Trading | Logon error received from server | 2020-06-15 15:57:08.477
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 15:57:08.477
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:57:08.477
DTC Client socket (1) | CloseSocket call. | 2020-06-15 15:57:08.487
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-06-15 15:57:08.487
Rithmic Trading | Disconnected. | 2020-06-15 15:57:08.487
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 15:57:08.487
DTC Client socket (1) | Close event error. Windows error code 10053: Software v hostitelském počítači ukončil vytvořené připojení. | 2020-06-15 15:57:30.242 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-15 15:57:30.242
DTC Client socket (1) | Closed. | 2020-06-15 15:57:30.242
[2020-06-15 16:11:46]
John - SC Support - Posts: 48003
Refer to the information here:
Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward
and here:
Regarding Rithmic (Our Final Post on this Subject)
[2020-06-16 06:12:18]
User446762 - Posts: 2
Hello, please advise, I can't connect to the data.
Thank you
Brokes
[2020-06-17 06:50:19]
Refer to:
