Date/Time: Thu, 17 Sep 2026 00:27:50 +0000
Feature Request: Lock Chart from being removed
View Count: 1053
[2020-06-15 11:31:26]
rahul - Posts: 173
Hello, may I please request a feature to disable removing a chart from the chartbook accidentally.
In my case, I have multiple charts in a chartbook that get loaded on startup. Some of these charts are dependent on each other. Please allow a way to disable accidentally removing a chart from the chartbook, something like "locking" a chart within a chartbook. To remove the chart, you need to "unlock" chart. If all charts are locked, the only way to remove is to close the chartbook.
Hope this request makes sense.
[2020-06-15 22:29:47]
User90125 - Posts: 715
+1
[2020-06-17 11:17:30]
There is already a prompt before a chart can even be closed. This prompt cannot be disabled.
Date Time Of Last Edit: 2020-06-17 11:17:44
[2020-06-17 11:20:41]
rahul - Posts: 173
Hmm... maybe I disabled the prompt by mistake, as it doesn't show up for me. It closes a chart without notification.
Can you guide me how to enable it again?
