Date/Time: Thu, 10 Sep 2026 11:46:01 +0000
Rithmic
View Count: 747
| [2020-06-15 11:04:27] |
| Titouan - Posts: 9 |
Hi, I can't connect to the rithmic data here is the log: Rithmic Trading | Port for executable: 2851 | 2020-06-15 10:58:58.528 Listening socket (1556). Port 2851 | Closed. | 2020-06-15 10:58:58.528 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-15 10:58:58.528 Created process C:\SierraChart\Rim\DTCBridge.exe. Current folder: C:\SierraChart\Rim | 2020-06-15 10:58:58.553 DTC Client socket (1) | Close event error. Windows error code 10053: Une connexion établie a été abandonnée par un logiciel de votre ordinateur hôte. | 2020-06-15 10:58:59.012 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-06-15 10:58:59.012 DTC Client socket (1) | Closed. | 2020-06-15 10:58:59.012 Rithmic Trading | Bridge process is not running! | 2020-06-15 10:59:00.560 Rithmic Trading | Connecting to the server 127.0.0.1. Port 2851 | 2020-06-15 10:59:00.560 DTC Client socket (1) | Creating socket. | 2020-06-15 10:59:00.560 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-06-15 10:59:00.560 DTC Client socket (1) | Connect event error. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2020-06-15 10:59:02.563 DTC Client socket (1) | CloseSocket call. | 2020-06-15 10:59:02.563 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-15 10:59:02.563 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 10:59:02.563 DTC Client socket (1) | Closed. | 2020-06-15 10:59:02.563 DTC Client socket (0) | CloseSocket call. | 2020-06-15 10:59:02.576 Rithmic Trading | Disconnected. | 2020-06-15 10:59:02.576 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-06-15 10:59:02.576 |
| [2020-06-15 11:09:32] |
Get the Rithmic bridge file and the updated TLS files from here: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
