Date/Time: Fri, 07 Feb 2025 19:54:55 +0000
[User Discussion] - Replaying Market Depth Data Recorded on Remote Instance
View Count: 524
[2020-06-15 08:48:08] |
User486465 - Posts: 12 |
Hi, I have the following setup: 1. A home server running an instance of SC which is used for recording market depth data. 2. My main trading PC running 2 instances of SC on the same network I want to know if the following is possible, if it is, I'll find the docs, just need to know if SC's architecture supports this: - I want to record market depth data using the home server. - I want both instances on the trading PC to be able to connect to the home server and replay historical market depth data by streaming it from the server, without having to record the data locally. Just a possible / not possible answer is fine. Thank you EDIT: Is this a case where I need to run a DTC Server on the home server (with depth recording enabled) and DTC Sub Instances on the client PCs? Date Time Of Last Edit: 2020-06-15 10:30:46
