Date/Time: Fri, 07 Feb 2025 21:15:34 +0000
3 bar pivot
View Count: 918
[2020-06-15 00:46:23]
User666853 - Posts: 6
Is there a study that'll help me plot 3 & 5 bar swing H/L pivots ? Specially as a dot? (This pivot comes from Gann terminology , not your daily pivots calculated from equations)
Also , how do i plot ES chart in same window with advance decline chart below ?
Thanks !
[2020-06-16 05:41:40]
I can't plot 3 bar pivot on sierra ?
[2020-06-16 06:18:13]
Ackin - Posts: 1865
Do you want this?
image5 bar HL.png / V - Attached On 2020-06-16 06:18:09 UTC - Size: 7.2 KB - 286 views
[2020-06-16 07:19:49]
Thank you , that looks okay . but can i just plot a single dot on actual 5 bar swing H/L & not plotting line of dots as resistance going forward like in your screenshot?
& can i change the setting from plotting 5 bar swing H/L to 3 bar swing H/L ?
What's the name of the study ? Thanks a lot !
[2020-06-16 07:59:12]
Ackin - Posts: 1865
This is a study from the default -list Sierrachart. You can change the graphic output in the Subgraphs DRAWSTYLE setting
Highest High/Lowest Low Over N Bars
If you want to make some adjustments and create a new study with the conditions, register on my CZSK forum and write a proposal there.
contact link:
have a nice day
[2020-06-17 11:14:12]
Regarding the second question in the first post, refer to:
Sierra Chart Market Statistics: Overlaying a Chart on Another Chart as a Study
