Date/Time: Fri, 07 Feb 2025 20:27:33 +0000
Help with charts
View Count: 535
[2020-06-14 15:36:26] |
User575399 - Posts: 326 |
My main charts are working a bit slow/lagging. When I open a new instance with the EXACT SAME chart book and layout it works fast. What could be the problem ?
[2020-06-14 19:06:17] |
Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Might be related to the Chart Update Interval. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-14 20:07:31] |
It’s the same on both main instance and new instance . I’ve literally tried everything on that list .
