Date/Time: Sat, 04 Jul 2026 04:33:57 +0000
Memory usage
View Count: 1343
| [2020-06-14 14:47:28] |
| User575399 - Posts: 348 |
My computer is only used for Sierra charts . I use a Ryzen 7 processor and 16gb of ram. I’m getting “very high “ memory on my task manager . How can I lower it? I’m only using 60days on my volume profile . Please don’t send me the “ help details “ link .
Date Time Of Last Edit: 2020-06-14 14:51:13
Private File |
| [2020-06-14 19:08:56] |
What is it that you are doing with Sierra Chart which is causing the high memory usage? You need to explain that to us. There is absolutely no way we would know the answer to this. Follow a process of elimination by gradually removing studies and closing charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-14 19:09:36
| [2020-06-14 20:06:24] |
I don’t think it’s anything crazy . I have a chartbook with ES futures charts and studies and Crude oil charts and studies . I even made a seperate chartbook with only ES and lowered the days to load on my charts and it’s still using a lot of memory. I’m confused as well . It’s a new computer too.
