Date/Time: Fri, 07 Feb 2025 20:20:08 +0000
Execute from new instance
View Count: 543
[2020-06-14 13:08:26] |
User575399 - Posts: 326 |
If I run a new instance on Sierra Charts. Can I execute trades from both ? Cause when I run a new instance it seems faster. Why is this?
Date Time Of Last Edit: 2020-06-14 19:11:30
[2020-06-14 13:32:20] |
Yes you can. For information about performance issues and to improve performance, refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
