Date/Time: Fri, 07 Feb 2025 20:04:10 +0000
Graphical problems with new install
View Count: 575
[2020-06-14 05:03:31]
User239541 - Posts: 1
I recently upgraded from an older laptop with Windows 8 to a new desktop with Windows 10. I’m running the same two 2k monitors on the new desktop that I had running off the laptop. I changed over my Sierra Chart settings per the help article, but ran into graphical problems with all chartbooks.
Basically, it looks like a really zoomed in version of my saved chartbook. I changed the font size to compensate, but it’s clearly zoomed in as it only shows the upper left corner of my chartbook, most of the charts are offscreen, and all the lines and drawings appear much thicker (and that’s on the smallest setting).
I’ve been unable to locate an answer and would appreciate any help as the thickness of the lines and drawings now renders my chartbooks busy and unusable.
From what I can tell, this problem seems to be affecting Sierra Chart only. I can provide pictures of before and after if necessary. Thanks.
[2020-06-15 00:38:07]
Use the Window >> Tile commands to update the position of charts to make them all visible:
Window, CB and CW Menus: Tile Horizontally (Window)
To adjust the widths Study Subgraphs and Chart Drawings, refer to:
Graphics Settings: Adjusting Graphics Settings and Fonts for High DPI Displays
