Date/Time: Fri, 07 Feb 2025 20:32:04 +0000
New instance
View Count: 678
[2020-06-13 17:11:28] |
User575399 - Posts: 326 |
Is it recommended to use a new instance for my DOM for faster execution Or fills ? Or will not make a difference ? Thanks
Date Time Of Last Edit: 2020-06-14 20:39:01
[2020-06-13 21:31:17] |
This is explained here: Overview of Trading: Sierra Chart Configuration for Most Low Response Time Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-13 21:42:21] |
So what is considered a high CPU usage that would actually slow down trading ? My CPU usage is only 11% on my Computer. My orders dont seem to fill as fast(on SIM as well)as when I use a new instance. But like I said , it shouldnt be the case with only 11% CPU usage. On "new instance" the orders go through as soon as I click the mouse. Not the case with my main chartbook.
Date Time Of Last Edit: 2020-06-13 23:26:43
[2020-06-15 01:04:35] |
There is absolutely no way we can know this. You have to make your own determinations about this. This is your own system. If you are noticing a problem, then follow the information here: Overview of Trading: Sierra Chart Configuration for Most Low Response Time Trading Also read through this page: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-15 01:04:57
[2020-06-15 01:42:04] |
I figured it out . Thanks
