Date/Time: Fri, 07 Feb 2025 20:02:47 +0000
Putting a Copy of Sierra on Windows 10 Laptop
View Count: 795
[2020-06-13 17:08:05] |
wingz - Posts: 121 |
I'm using Sierra 64 bit on a PC with Windows 7. I'd like to put a copy of what I have on my PC onto my laptop, which has Windows 10. I'm using Denali data. Is there a way to put an exact copy of my Sierra onto the laptop?
[2020-06-13 21:21:28] |
Refer to: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
