Date/Time: Sat, 08 Feb 2025 04:37:43 +0000
fills display
View Count: 722
[2020-06-12 20:13:34] |
User284416 - Posts: 27 |
Hello I'm having some troubles with fills displaying on HG/QC - they're moved right http://www.sierrachart.com/image.php?Image=1591992483941.png I'm also using the same ES/MES and CG/GR setup and they don't have any problem. |
[2020-06-15 01:09:50] |
We are not fully understanding this, but refer to: Chart Trading and the Chart DOM: Misaligned Order Fill Markers on Charts Make sure the scale of the chart is set to an Automatic Scale Range: Chart Scale and Scale Adjusting And also remove all studies from that chart, to rule out a study causing a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-15 01:11:08
[2020-06-26 19:23:54] |
hello i tried to delete and reload data, time settings are as global and as my laptop, scale is set to automatic and no studies at all on the chart. as i mentioned i'm using the same standard and micro "as trade only symbol" setup on s&p and gold futures and no issues ever with them, it's just something wrong with standard and mini copper, no problem with other instruments |
