Date/Time: Fri, 07 Feb 2025 20:54:26 +0000
Bracket Orders with Scale In
View Count: 719
[2020-06-12 20:00:39] |
samual sprat - Posts: 343 |
Hi, Is this requested feature available now? Looks like it caused issues when it was first implemented but it's a great addition. If it's in there how do I enable it? See: Bracket Orders with Scale In Thanks S |
[2020-06-13 10:47:37] |
Yes the even distribution of orders during a Scale In and Scale Out are fully supported.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-13 10:48:26
[2020-06-14 00:28:52] |
Doesn’t appear to be enabled by default for me, is there a switch somewhere? Thanks |
[2020-06-17 03:15:45] |
You need to use this setting: Global Trade Settings Windows: Scale In (Global Settings >> General Trade Settings >> Scale In/Out) You need to set it to Even Distribution but we see there is a problem with the orders not fully evenly distributing and that is now resolved in version 2123. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-17 03:16:09
