Date/Time: Sat, 08 Feb 2025 02:16:59 +0000
Message log window popping up on every program start
View Count: 580
[2020-06-12 17:39:56] |
User495158 - Posts: 108 |
Hi! Since recently I have message log window popping out whenever I start SC. The only error I could find is marked with this line: "Error opening C:\SierraChart\MenuCustomizations.xml. Windows error code 2: The system cannot find the file specified." I don't use any language customizations. How can I solve this problem? Thanks |
[2020-06-12 19:00:51] |
We will look into this and resolve.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-12 19:03:24
[2020-06-23 18:27:20] |
Resolved. Created empty MenuCustomizations.xml file.
[2020-06-23 20:49:17] |
Okay but this will be fully resolved in the next release.
