Date/Time: Fri, 07 Feb 2025 20:26:55 +0000
rithmic paper trading connection error
View Count: 1420
[2020-06-12 17:26:40]
User593307 - Posts: 1
When I try to connect rithmic paper tarding on sierrachart I get this error.
Rithmic Trading | Port for executable: 63838 | 2020-06-12 17:13:14.188
Listening socket (1872). Port 63838 | Closed. | 2020-06-12 17:13:14.188
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2020-06-12 17:13:14.189
Error creating process C:\SierraChart\Rim\DTCBridge.exe. Windows error code 2: The system cannot find the file specified. | 2020-06-12 17:13:14.189 *
Rithmic Trading | Error running DTC server program C:\SierraChart\Rim\DTCBridge.exe. Rithmic bridge needs installing. To obtain the bridge files, go to: Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward | 2020-06-12 17:13:14.189 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-06-12 17:13:14.189
[2020-06-13 01:26:47]
You need to install the updated files. You will find them here:
