Date/Time: Fri, 07 Feb 2025 19:41:26 +0000
Ticks Conversion
View Count: 932
[2020-06-12 15:42:12]
User94606 - Posts: 327
I am currently using "Study Subgraphs Difference" to determine the spread of NQ (Ask - Bid). The difference of this calculation is the spread between the ask and bid in points. How do I convert this difference to ticks?
[2020-06-12 17:52:42]
Ackin - Posts: 1865
Try:
Study Subgraph in Ticks
Study Subgraph In Ticks
[2020-06-12 18:12:44]
Thanks. How do I remove the zeros from the Study Subgraph in Ticks calculation? The tick difference is showing 4.00 and I just want to display 4
[2020-06-12 19:18:01]
Ackin - Posts: 1865
Try change "Value format" in the settings of this study
[2020-06-12 20:47:23]
There is no value format in the settings. Thanks for your help
[2020-06-12 20:56:08]
Ackin - Posts: 1865
imagetick value.png / V - Attached On 2020-06-12 20:55:41 UTC - Size: 70.72 KB - 230 views
[2020-06-12 22:18:40]
I did have the 1 as the value format and still shows the decimal when I display using Text Display for Study
[2020-06-12 23:02:51]
Ackin - Posts: 1865
So do the same with the value format in the Text Display for Study. This is usually done in the study that is at the end of all the studies used
Study diff -> Study tick -> Text Display .. Value Format change
[2020-06-12 23:25:12]
Got it. Thank you !
