Date/Time: Fri, 07 Feb 2025 19:59:51 +0000
Backups
View Count: 568
[2020-06-12 13:24:02] |
trading2themoon - Posts: 46 |
Windoze decided it was more important to restart for a software update than let me decide if it was safe to do so, losing hours and hours of work while I was running a test. Any chance SC makes regular backups? I don't see anything useful in the backups folder but thought I'd check. Perhaps a temp file somewhere? |
[2020-06-15 00:44:55] |
There is an option to automatically save Chartbooks periodically: General Settings Window: Auto-Save Chartbooks (Global Settings >> General Settings >> Charts >> Chartbooks) Here is the documentation for backup Chartbooks: Chartbooks (Workspaces): Accessing a Backup Chartbook File And for spreadsheets: Working with Spreadsheets: Accessing a Backup Spreadsheet File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
