Date/Time: Fri, 07 Feb 2025 20:07:20 +0000
About 64-bit version SC
View Count: 568
[2020-06-12 10:12:07] |
User513952 - Posts: 85 |
Hi, For 64-bit version SC, each time when I tried to click Add Custom Study, the SC always automatically exited and the custom studies window cannot be loaded. For the custom studies I added in 32-bit SC, they can be shown in 64-bit SC. PLease advise how to add custom study in 64-bit SC. Thanks Charlie |
[2020-06-13 00:38:28] |
There must be a problem with one of the 64-bit DLLs that you have. You need to remove the faulty one. This is explained here: Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface: Problems Caused by Advanced Custom Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-13 00:38:50
