Date/Time: Mon, 25 Nov 2024 07:23:39 +0000
SC has automatic fill opening gap on historical daily chart?
View Count: 1977
[2014-01-26 03:39:04]
User70622 - Posts: 7
I checked with recent 2 days 5-min chart, in 5-min chart they did have opening gaps. But in daily chart,it shows the gap has been filled and today's open is exactly yesterday's close. So did I missing some setting in chart setting? Thank you!
[2014-01-26 05:46:29]
We are not clear at all as to what you are describing here. Please provide chart images:
https://www.sierrachart.com/index.php?l=PostingInformation.php#Image
[2014-01-26 13:07:41]
Here is the 5-min chart page.You could clear see there is gap between day1 and day2. So in daily chart,it should have been clear gap between 2 days.
http://www.sierrachart.com/image.php?l=1390741406574.png
Here is the daily chart page.First bar is Day1 and the second bar is Day2.
http://www.sierrachart.com/image.php?l=1390741588723.png
So may I wonder is there any setting in daily chart that request to fill the gap between 2 bars? I may choose it by mistake.
Thanks!
[2014-01-26 19:14:46]
User16114 - Posts: 153
for your Daily Chart try using an Intraday Chart with regular Session Times
Chart Settings>>Main Settings; "Intraday Chart" Bar Period "Days-Mins-Secs-Per Bar" "1-0-0"
Put in regular session "Start Time" and "End Time" and leave "Evening Session" unchecked
[2014-01-26 19:37:47]
This is how the FXCM Historical Daily price data is.
The suggestion given in post #4 is a way around this.
[2014-01-27 02:37:15]
Thanks a lot!The issue has been solved.
[2014-01-27 08:44:38]
Another question,this solve the issue on daily chart. How about the weekly chart and monthly chart?
Weekly chart set to 7 days? And monthly chart?
