Date/Time: Fri, 07 Feb 2025 18:11:10 +0000
Order type error
View Count: 487
[2020-06-12 01:44:03] |
User663121 - Posts: 7 |
Dear SC, When I place any limit order, and as soon as my limit order was filled, the "stop" order automatically changed to "stop-limit" order,how do I fix it up? Thank you SC. |
[2020-06-12 10:04:35] |
Refer to: Order Types: Stop Orders on the CME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
