Date/Time: Mon, 10 Mar 2025 23:14:12 +0000
Dedicated SSD for Sieera Chart
View Count: 2293
[2020-06-11 22:24:54]
User377189 - Posts: 209
Recently one of my RAM sticks malfunctioned so i will be upgrading my RAM from 16 GB (2*8GB) to 32 GB (2*16GB). I also came across a thread mentioning for best performance Sierra Charts should be installed on a dedicated SSD, and decided if i am making the RAM upgrade should get a dedicated M.2 NVME SSD as well dedicated for Sierra Charts
- I already have 1 500GB M.2 NVME SSD as my main hard disk
- I am adding another 500GB M.2 NVME SSD for Sierra chart
- I already have Sierra chart installed on my system, is there documentation/best practices on how to set this up and things to consider before doing this
- Will i need to re-download Sierra Charts or can i simply transfer from c:\\ to the new drive that will be dedicated to the dedicated Sierra SSD. I do not want to loose my chart-books and other settings
[2020-06-11 23:30:02]
Yes. But refer to:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Simple Transfer/Copy of Sierra Chart Installation to Another Folder or Computer System
[2020-06-12 00:35:12]
Great.
So, other than instructions mentioned in above link there are no other considerations/requirements when dedicating an entire m.2 nvme ssd for sierra chart
[2020-06-12 02:37:08]
Right.
[2020-06-13 14:39:33]
Awesome
Thank you this worked. All set for now.
I got a 500 GB m.2 NvMe dedicated to Sierra charts. Is this overkill? How much storage does Sierra need? Want to re-assign the balance to v-ram
My system:
- 2 - m.2 NvMe 500 GB SSD's (one dedicated to Sierra Charts)
- 32 GB RAM (2*16 GB)
Waiting for RAM to come but previously while i had 16GB RAM (2*8 GB) and on initializing Sierra i noticed by Memory used to spike to 100%.
By upgrading the RAM and dedicated SSD should reduce load.
But as one SSD is dedicated to Sierra i can use possibly 50-100 GB as v-ram :). Want to future proof myself the best way i can
Date Time Of Last Edit: 2020-06-13 15:18:02
[2020-06-26 00:14:54]
User256155 - Posts: 20
Getting this for myself as we speak - Samsung 970 plus NVME running at full speed.
Benchmarked it and holy crap it's fast. Getting it all together will post back here after I use it a bit.
