Date/Time: Fri, 07 Feb 2025 18:18:26 +0000
Rollover for NQ and YM
View Count: 619
[2020-06-11 21:34:31] |
User357195 - Posts: 123 |
SC: I have my Sierra Charts set to automatically rollover based upon VOLUME. Why did NQ and YM roll to U-Sept from M-June when M-June clearly had more volume yesterday, 06-10-20 and they still do today, 06-11-20? I believe the most volume will come into NQ and YM for U-Sept starting at the regular trading hours open of 9:30 ET tomorrow, 06-12-20. If I go to Chart > Chart Setting > Advanced Settings and Continous Contract, I have it set to Continuous contract - Volume Based Rollover? SC charts are the best. |
[2020-06-12 10:03:50] |
You must therefore have this option enabled in the Chart Settings: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
