Date/Time: Fri, 07 Feb 2025 17:57:55 +0000
Rollover help please...
View Count: 588
[2020-06-11 20:18:04] |
User731023 - Posts: 139 |
On the ES June contract it is .25 short after rollover. I have tried 10 times with different variations. Can not get it to adjust. I now have chest pains. Pleas instruct. Thank you |
![]() Attachment Deleted. |
[2020-06-12 10:01:32] |
You need to enable the Custom Symbol Settings values option: Global Symbol Settings: Use Custom Symbol Settings Values (Global Settings >> Symbol Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
