Date/Time: Fri, 07 Feb 2025 18:20:25 +0000
Password error message
View Count: 828
[2020-06-11 19:29:14]
User597876 - Posts: 42
I had trouble logging into my trading platform a couple times today. I will attach a photo with the message.
Private File
[2020-06-11 19:38:24]
Restart Sierra Chart and follow the Forced Login instructions:
Sierra Chart - Software Login Instructions: Forced Login
Let us know if you have a further issue. Did you change your Sierra Chart password today?
Date Time Of Last Edit: 2020-06-11 19:38:32
[2020-06-11 19:52:46]
I sent you the message log file. It mentions problems about my services.
[2020-06-11 19:53:46]
No, I have not changed my password.
[2020-06-11 19:55:48]
Ok we will check.
[2020-06-11 19:59:26]
Is there anything unusual about the Internet connection you are using? We see a connectivity problem with historical data.
HD Request # 4 | Error downloading historical Intraday data for MESU20_FUT_CME. Timeout error connecting to server. | 2020-06-11 14:47:50.412
For help with this, refer to:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Error when Downloading Historical Intraday Data from the Sierra Chart Historical Data Server
We see you are using this symbol: MESU20_FUT_CME
Change back to the June contract:
Changing the Symbol of a Chart: Changing the Symbol of a Chart or Trade DOM Through Chart Settings
Date Time Of Last Edit: 2020-06-11 19:59:55
[2020-06-11 20:14:50]
I ran a ping test from cmd prompt. Everything looks good. I have a 1GB cable connection.
[2020-06-12 10:02:33]
If you continue to have trouble with historical Intraday data, there is still some connectivity problem. Refer to the information here about this:
