Date/Time: Fri, 07 Feb 2025 18:11:19 +0000
"SC Data All Service" not enabled
View Count: 587
[2020-06-11 17:33:47] |
User740326 - Posts: 3 |
Hello, I have Sierra Chart package 3, where SC Data all service is should be included. In my Data/Trade service settings "SC Data All Service" not enabled... Please enabled SC Data all services for me! Because included to "package 3" Thanks Best Regards Tamas |
Attachment Deleted. Private File |
[2020-06-11 18:45:42] |
Direct Sierra Chart Account When you are using Sierra Chart that has been provided through an affiliate, you do not have a direct paid account with us, and you wish to access functionality that is not provided in your limited version, you must have an account with Sierra Chart directly and have a standard installation of Sierra Chart. To accomplish this, follow the instructions below: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
