Date/Time: Fri, 07 Feb 2025 20:22:18 +0000
Couple Questions on DOM
View Count: 621
[2020-06-11 17:16:49] |
Dt111111 - Posts: 5 |
Hello, My first question is on recentering the doms. I know you can set a hotkey to recenter all DOM's, which I have. I also know you can double click on each individual DOM to recenter as well. But my issue is the recenter all hotkey does not work it a certain scenario and I was wondering if it is possible to make it so. I have sierra open, with main instance on one monitor, with a chartbook containing tiled graphs open. Then my DOMS are technically attached to another chartbook, however, I have all of them detached and a separate monitor with only detached DOMs. So, when I have my charts chartbook up on the main instance, the hotkey does nothing. I realize one way would be to attach the DOMs I have detached to that same chartbook, but I don't only use one chartbook for charts on the main instance. Wondering if there is a way to make the recenter hotkey work on every single no matter what chartbook is currently selected on the main instance. Second question, I use an indicator on the DOM for an opening range. Is it possible to get the lines in the indicator column to carry over into the values column, and work the same way the daily high low lines do? Thanks |
[2020-06-15 00:52:56] |
Wondering if there is a way to make the recenter hotkey work on every single no matter what chartbook is currently selected on the main instance. We will look into this.Second question, I use an indicator on the DOM for an opening range. Is it possible to get the lines in the indicator column to carry over into the values column, and work the same way the daily high low lines do? Refer to this Subgraph setting:Chart Studies: Subgraphs Tab >> Name and Value Labels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-15 00:53:13
