Date/Time: Fri, 07 Feb 2025 17:54:17 +0000
Precio
View Count: 456
[2020-06-11 16:55:31] |
User606185 - Posts: 1 |
Buenos días He configurado la grafica en ticks pero el preciono tiene movimiento alguno, me podrian indicar que puedo hacer como solucionar esto. Gracias. ****** Good morning. I have configured the graph in ticks but the price has no movement, could indicate me that I can do as solve this. Thank you. |
[2020-06-11 19:23:17] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
