Date/Time: Fri, 07 Feb 2025 20:29:34 +0000
Historical data & sub-instances
View Count: 557
[2020-06-11 15:16:52] |
User907968 - Posts: 826 |
I am seeing a recurring problem downloading historical data into sub-instances. I use a server instance of SC to connect to denali, then feed everything else directly or indirectly from this. 1) Server Instance -> Child Instance : often historical data has to be triggered using 'delete and download data' 2) Server Instance -> Child Instance -> Child of Child Instance : 'delete and download data' does not trigger downloading of historical data 'Child Instances' are configured manually to connect to the server instance 'Child of Child Instances' are created using 'File' -> 'New Instance' command This setup worked previously, very reliably, but does not any longer. Is there now some setting that needs to be changed to make this work again? I have zero problem with intraday data, this is still working very well. |
[2020-06-12 18:58:36] |
Refer to the documentation here in regards to this: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Historical Data and Missing Historical Data This is not a supported configuration: 2) Server Instance -> Child Instance -> Child of Child Instance : 'delete and download data' does not trigger downloading of historical data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
