Date/Time: Fri, 07 Feb 2025 20:23:09 +0000
Variable Stop Loss
View Count: 610
[2020-06-11 13:52:26] |
User418587 - Posts: 5 |
Is there way to have a variable stop loss connected to the trading system based on alert condition? For example, if the trading system alert condition activates to take a buy trade on a certain bar, I want the stop loss at the bottom of that bar, which may be 10 ticks. On another trade, however, the bottom of the bar may be 5 ticks. Is there a way to essentially program a stop loss at the bottom of a bar knowing that the stop loss will always be a different size because of bar size? thanks
[2020-06-12 19:22:45] |
For this you would need to use the Spreadsheet System for Trading study: Spreadsheet Systems, Alerts and Automated Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
