Date/Time: Fri, 07 Feb 2025 18:26:03 +0000
automatic rollover for YM today
View Count: 696
[2020-06-11 07:33:11]
User275592 - Posts: 97
today sc is displaying YM september after automatic rollover
could you explain what happened ?
Thank you for your help
[2020-06-11 08:11:49]
So you must have this setting enabled:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html&CAID=default#AutomaticallyRolloverFuturesSymbol
[2020-06-11 08:14:24]
the problem is that the official rollover was not planned today
Why sc did the rollover before the official one ?
[2020-06-11 08:57:01]
How do you come to this conclusion? We need a detailed explanation with calculation and a reference to Sierra Chart Symbol Settings and references as to your conclusion.
Date Time Of Last Edit: 2020-06-11 08:57:49
[2020-06-11 09:06:33]
this is not a conclusion but an hypothesis, i should have written that differently
on chart setting, automatic rollover futures symbol is on
thank you for your help
[2020-06-11 09:09:05]
Really what you are looking for is a volume-based rollover not the official technical rollover. This is why the automatic rollover option really is not recommended. And the documentation we linked to above, explains everything in detail.
[2020-06-11 09:11:58]
the future contract displayed with automatic rollover on is YMU0
I put automatic rollover off, change the contract to YMM0, close sc, reopen sc
I get a message symbol needs rollover
when i put automatic rollover on, the contract is changed in YMU0
[2020-06-11 09:32:11]
User413445 - Posts: 2
hello
got same problem today with ES and MES - had on rollover by volume, contracts was changed on September, but its volume still much lower then June.
Then I changed rollover type to "date", saved all, closer and reopened terminal - same, contracts was changed again from june to september - no logic at all.
Terminal was updated yesterday.
[2020-06-11 14:42:19]
nicktrader - Posts: 734
The default Rollover Method is wrong. You have to customize it (CQG)
See pic.
imageRollover.png / V - Attached On 2020-06-11 14:42:08 UTC - Size: 29.91 KB - 243 views
[2020-06-11 16:26:10]
this works, thank you!
interesting, rollover was wrong always or just recently?..
[2020-06-11 18:39:05]
The default rollover rule is correct. It is the official rollover rule.
The easiest solution is to increase this setting:
General Settings Window: Additional Days to Add to Rollover Date for Chart and Quote Board Rollovers (Global Settings >> General Settings >> Charts >> Charts)
Or just disable the automatic rollover option.
