Date/Time: Fri, 07 Feb 2025 18:08:27 +0000
Issue with changing symbol across linked charts
View Count: 481
[2020-06-11 05:02:24] |
Ala - Posts: 8 |
Hello there, I've connected my SC software to my Interactive Brokers account, while retaining Denali as the data feed. The issue I have is that after translating the symbols, one chart (my main chart) was running June's ES symbol, while all other charts were running September's. I have all charts linked to link #1, and the Symbol link checked, but when I try update the chart symbol to June the other linked charts do not update and I have to go through them manually, although it used to work fine when I was trying SC using a Rithmic trial account. Any idea what may be causing this? |
[2020-06-11 19:27:20] |
You may not be using chart linking properly. Full documentation: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber Or there is some other unknown circumstance going on which we are not aware of. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-11 19:27:32
