Date/Time: Thu, 17 Sep 2026 21:53:06 +0000
Package 5 demo request.
View Count: 931
| [2020-06-10 15:49:49] |
| User929084 - Posts: 60 |
Hi. Currently I have sierra through AMP. I know I already used 2 week demo trial before, but at the time I wasn't aware/ didn't use tools that are in package 5. Is it possible to get another 2 week demo trial for package 5. Thank you. |
| [2020-06-10 18:25:26] |
Yes we can give you a trial of package 5. There is a technical issue though related to your account when activating this that we are looking into.
| [2020-06-10 18:30:37] |
OK. Let me know what I need to do once issue is resolved. Thank you. |
| [2020-06-10 18:44:50] |
The trial for package 5 is now enabled: (Evaluating Package 5 until 2020-07-10)
| [2020-06-11 12:57:07] |
Thank you.
| [2020-07-08 01:05:48] |
I will keep package 5. Right now I get SC package 3 through AMP. I want to get it directly through SC. Besides depositing money in the account for package 5 is there anything else I need to do? I just want to keep the email associated with this account since it's my primary email. |
| [2020-07-08 10:19:31] |
Refer to this page: Direct Sierra Chart Account And you will also need to set up the Denali Exchange Data Feed on your Sierra Chart direct account: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
