Date/Time: Sat, 05 Apr 2025 00:56:48 +0000
Simple or impossible alert question
View Count: 4625
[2014-10-15 09:07:29]
Matt654 - Posts: 73
Hi Support its been days now and still no reply.
Sierra Chart Engineering continuously monitors the Support Board and it is given the highest priority.
Hi Support could you post the formula for the Subgraph alert for Point & Figure turning green and then another one for turning red. Matt
[2014-10-15 12:51:40]
mkata - Posts: 103
Matt654,
May I suggest starting your own request thread rather than tacking your request to the end of someone else's old thread.
You may have better luck that way.
[2014-10-15 20:39:16]
Matt654 - Posts: 73
Okay Thanks Mkata I'll try that.
Matt654,
