Date/Time: Fri, 07 Feb 2025 18:19:42 +0000
Do not see Fill Markers on my charts
View Count: 578
[2020-06-10 13:28:35] |
User310898 - Posts: 43 |
Hi I have always seen the little fill markers on my chart but they have disappeared and I am sure it is a setting but I cannot find it anywhere! Please can you help me. I have attached a chart showing that I have everything turned on to show it but yet I cannot see those little tiny triangles (fill markers). Can you help - much appreciated! |
[2020-06-10 18:21:19] |
First thing is to update to the current version of Sierra Chart: Software Download: Fast Update Then adjust this setting to the number of pixels you want them to be based upon: Global Trade Settings Windows: Fill Marker Size (Global Settings >> Chart Trade Settings >> Order Fills >> Order Fills) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
