Date/Time: Fri, 07 Feb 2025 18:24:57 +0000
scaling to indicator
View Count: 821
[2020-06-10 12:32:07]
User170575 - Posts: 221
hi--could you plz point me to how to scale the chart to an indicator? Or just simply to use the hod/lod as the top and bottom of
the chart and excluding all other indicators/prices/drawing and so on?
many thx
cy
[2020-06-10 18:17:02]
To include an indicator in the chart scaling, just make sure that the indicator has its scaling set to "Automatic". Refer to the information here:
Chart Studies: Settings and Inputs Tab >> Scale
Or to exclude it, refer to:
Chart Scale and Scale Adjusting: Basing Scale Only on Price Bars
If you want to use the High/Low of the Day as the Top and Bottom, then this is the same as the above. You would need to use the Daily OHLC study and set its scale to "Automatic" and all other studies to "Same as Region". Refer to the information for Daily OHLC here:
Daily OHLC
