Date/Time: Fri, 07 Feb 2025 18:20:47 +0000
Incorrect DPL when using different trade symbol
View Count: 913
[2020-06-10 11:39:22] |
chart_warrior - Posts: 96 |
I have "F.US.MESM20" set as trade symbol on a "F.US.EPM20" chart. Orders go through fine but daily P&L is showing as if it's done on mini ES rather than micro. Symbol settings look correct, value tick set to 1.25. Any idea? |
[2020-06-10 18:05:27] |
Check the Currency Value Per Tick setting in the Chart Settings: Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-10 18:09:14] |
That worked. Thank you!
